can't read ECU, need help
Old Jul 23, 2007 | 01:30 AM
burgers22's Avatar
So the map you flashed could well have a diffrent init code. This might explain why you can no longer access your ECU. Try ECU unlocker from the above address as I suggested.
It is bad practice to flash the whole ROM unless you are very sure that the image will match the cars hardware, and you are experienced in accessing the ECU when locked out, or changing immobilizer codes.
MB
Old Jul 23, 2007 | 01:47 AM
kittio's Avatar
Then we know what the problem come from and i try fix it by using your suggesion.
Thanks
Old Jul 23, 2007 | 07:18 PM
kittio's Avatar
The problem has been solved.
Thanks
Old Oct 9, 2007 | 03:30 PM
admech's Avatar
What did you do to fix the problem?
Just wondering what you did to fix the problem? I'm having the same issue and the past 10 posts I've searched say problem solved or nothing at all, the threads just end. Thanks ,
-Steve
Old Jan 18, 2008 | 11:09 AM
kilawind's Avatar
[QUOTE=kittio;4569345]The problem has been solved. What is the solution on this problem?
Jhova5
Oct 18, 2015 05:06 AM
Frew
Mar 25, 2012 02:04 PM
Dub
Nov 23, 2009 01:37 PM
pqek666
Oct 15, 2009 07:15 AM
gamebred26
May 12, 2008 06:09 AM
