How can i tuning my ECU ?
Old Jul 24, 2007 | 02:18 PM
Sodré's Avatar
Hi, i have a Ecuflash, but i cant modify my ecu...
I just want turn off the Boost cut (i want use abaut 25psi)
How i do?
Thanks
Old Jul 24, 2007 | 03:13 PM
Mr. Evo IX's Avatar
Your question can be answered on a very basic level but if your asking this simple question you should do alot more reading before modifying any parameters in your ECU. In fact you should enlist the assistance of a professional or do enough reading that you can answer this question yourself.
Also 25psi without having a solid custom tune is asking for your rods to be on the outside of your block. The boost cut is there for a reason.
I had written an entire how-to change your boost limit setting and then deleted the post because I dont think it's a wise thing to do without knowing what your doing. You'd be much better off buying a flash from one of the vendors here than modifying the ECU yourself without experience.
Mellon, TTP, Jestr, and others offer affordable e-flash services and your car will run better as well.
Old Jul 24, 2007 | 11:37 PM
TTP Engineering's Avatar
Agreed, we have tuned many Evos in Brazil, Dominica, Peru, Columbia. Just reflashed an FQ-360 also. We can take care of you. Send us a PM.
Old Jul 25, 2007 | 03:58 AM
burgers22's Avatar
Hi Sodre
Can you tell us what problems you are having? Can you download your ROM ok? And can you see the maps? What is your year and model of car, what is the ROM ID
Chaps, it maybe simple to us, but if your a new to this some of the starting procedures can be a bit tricky, maybe the OP has a locked ECU, maybe there is no def file of his ROM ID in his install, either one is more of a pain to sort out than changing the boost cut.
Having said that, make sure you log your ECU, and definitely get a wide band O2 sensor.
MB
Old Jul 25, 2007 | 02:23 PM
Mellon Racing's Avatar
Mellon Tuning is the official tuner for all of Brazil!
just kidding, let me know if you need help.
Old Jul 25, 2007 | 03:19 PM
La TTP-Engineering tiene la satisfacción del cliente más alta de cualquier afinador de reflash. ¡Mire nuestras calificaciones de la reacción!
Old Jul 25, 2007 | 03:36 PM
cfdfireman1's Avatar
Talking Nice try TTP
They speak Portuguese in Brazil.
how's this?
A TTP-Engenharia tem a satisfação do cliente o mais elevado de todo o tuner do reflash. Preste atenção a nossas qualificações da reação!
Old Jul 25, 2007 | 03:46 PM
budlong's Avatar
lol...
Old Jul 25, 2007 | 05:14 PM
how's this?
O ponto é que fizemos um esforço faz ele mais fácil no freguês entender. Nós não escrevemos fluentemente em português.
Old Jul 25, 2007 | 05:18 PM
budlong's Avatar
o babelfish balança o doesnt ele?
Old Jul 25, 2007 | 05:22 PM
Eu nunca usei o babelfish!
Old Jul 25, 2007 | 05:34 PM
mifesto's Avatar
Old Jul 25, 2007 | 05:35 PM
budlong's Avatar
http://babelfish.altavista.com/
Old Jul 25, 2007 | 05:36 PM
You just did
O yes you do.
Old Jul 25, 2007 | 08:38 PM
Vigman's Avatar
Anyway, the thing is you need to take care moving something you do not know about....
with babelfish:
Em todo o caso, a coisa é você necessidade ciao que move algo que você não sabe sobre....
