Different a/f in each gears at same load??
Old Jul 30, 2007 | 07:04 AM
erggy's Avatar
Guys, I've posted a question before asking for some advice on why I'm getting richer and richer a/f as i go up the gears (3-4-5th). Some have recommended me to see if I'm getting higher loads in higher gear, leading to richer a/f from looking at a diff cell on the ecu map.
I've done some logging today and saw that the loads between 3rd 4th 5th are pretty much relatively close to each other but the a/f are still quite different.
I'm attaching a picture of LoadCalc vs. A/F for your reference.
Any advice is much appreciated!!
Attached Thumbnails Different a/f in each gears at same load??-af-vs-loadcalc.jpg
Old Jul 30, 2007 | 08:12 AM
Jorge T's Avatar
Leanspool will lean out AFR on the gear you start at WOT. Seach leanspool there are several threads on the topic.
Old Jul 30, 2007 | 08:47 AM
erggy's Avatar
Thanks, but u mean leanspool will lean out the gear I start at? I think a/f of my 3rd gear is OK and don't want to go leaner than 11.7 but I want to richen out 4th and 5th...
Old Jul 30, 2007 | 09:08 AM
Ralph's Avatar
Disable leanspool.
Old Aug 19, 2007 | 01:25 AM
erggy's Avatar
Originally Posted by Ralph
Disable leanspool.
not sure if I can disable leanspool for a JDM EVOVII... if not, not sure if adding fuel from 2,500-4,000 would help to eliminate lean spool? thanks
Old Aug 19, 2007 | 01:34 AM
tephra's Avatar
so lean spool affects some gears over others?
jameswwt
30
Apr 13, 2011 07:15 AM
AlwaysinBoost
Aug 5, 2006 03:16 PM
djmikeymike
28
Sep 26, 2005 11:01 AM
maikonkun
27
Aug 12, 2004 07:56 AM
cjb
33
Dec 7, 2003 05:54 PM
