Can't datalog..with either mitsulogger or evoscan
As the title says..evoscan will not intialize...with mitsulogger its sampling rate is super slow (2-3 data points during a 3rd gear pull)
But I can read/write to the ecu fine using ecuflash
its a P4...ive logged with it in the past...dunno what changed. It is a new map, but just very small changes were made
I cna flash/dl the maps, but cant log.
I have a similar problem, Evoscan initilizes then immediately disconnects because it gives me a "cannot open com port 1" then "unable to local file" then shuts down...
Mitsulogger works, but freezes and dies when i tell it i have an LC-1
after logging successfully with my friends laptop using my table, I figured something funky musta happened with the drivers or something, So i uninstalled ecuflash+evoscan, reinstalled, now it logs fine
i was having the initializing and then deactivating problem... if you read the little box i was missing a dll file.. i google and download the file... also make sure if you are trying to log wideband, that you have a wideband and it is being used through the correct setting/choice (ie innovative ect.) try unchecking most of the logs, go with engine speed and rpms, the basics, and work your way up... thats what i had to do... some of the logs wont log, and with that your logger will disengage immediately after engaging
good luck
good luck
I just, just had this problem. I am so peeved right now. Interesting thing though. Right prior to that I downloaded my ECU's ROM. Go figure?
In my case I was on the usb/mitsu box, and it still said there was a problem with COM 1.
