Injector Scaling in ECU Flash
Old Aug 11, 2007 | 06:27 PM
BiFfMaN's Avatar
Quick question because i couldnt find anything on this subject.
When i go to edit the Injector Scaling it shows 3 dots and not the Number of the injector CCs. This is on a Evo 9 ecu...any help would be nice.
Old Aug 13, 2007 | 10:19 AM
MR 600's Avatar
+1, I am having the same problem and was just going to post about it, please help !
Old Aug 13, 2007 | 10:39 AM
mplspilot's Avatar
Wrong definition file?
Old Aug 13, 2007 | 01:19 PM
MR 600's Avatar
Old Aug 13, 2007 | 04:48 PM
BiFfMaN's Avatar
Hey i found out the issue..its a bad .hex file....just go to aktive matix and download the file there..change your immobilzer code (use 0x like it says) and bang! fixed my problem and OMFG...
as a precausion i reloaded the ECU flash program also...
Hope this helps you all.
Old Aug 14, 2007 | 11:18 AM
MR 600's Avatar
I am at the D/L section, but D/L what file exactly ? How do i change the Immobilizer code?
Can you please walk me through it, i am a newb at this and i am overseas and cant really take my EVO to a shop/tuner to get this done...
Any help would be great, thanks in advance
Old Aug 14, 2007 | 07:19 PM
BiFfMaN's Avatar
i found the stock .hex file here...
http://www.aktivematrix.com/forum/dl...file&file_id=3
ok and get the latest version of ecu flash here..1.30
http://www.openecu.org/index.php?title=EcuFlash
now once you are in open your stock hex file and scroll down to the immobilizer code...should be 4 digits all upper case. now open the new .hex file, open the immobilizer and change it by typing 0xXXXX..the last 4 "x"s being your code. it will say it also on the edit window how to do it.
Ok now with that done just flash in the other Stock rom and should be tuneable now.
but word of advice...be carefull with this program...i have seen a few guys already blow up their Evo 9's because of this. Its best to be taught how to use it and what it effects. Logging programs and a wideband is a must.
just be carefull....need to keep our cars running right =)
Old Aug 15, 2007 | 07:16 AM
MR 600's Avatar
Thanks man, i got it to work....
My EVO has the early version 13 .... Is there anyway to be able to adjust 13 so i can change the "injector scaling" (enable injector scaling in 13) instead of uploading the newer 15 ??
Thanks
Old Aug 15, 2007 | 04:26 PM
BiFfMaN's Avatar
Thanks
I couldnt find a way to fix the V13...so i just loaded in V15...but so far everything is great.
BarryC
Mar 22, 2009 07:07 AM
Evo H8
Dec 2, 2008 05:22 PM
Evolessfornow
Mar 1, 2008 08:26 AM
smokedmustang
Aug 4, 2006 08:52 AM
240Z TwinTurbo
Jul 12, 2006 11:06 AM
