LoadCalc to PSI
Old Aug 13, 2007 | 07:19 AM
cladden's Avatar
LoadCalc to PSI
I’m trying to convert engine load to boost using EvoScan v0.99.
Am I correct in thinking that I can just back out the “loadcalc” from EvoScan v0.99 to determine boost?
I guess I would need to know my atmospheric pressure.
Looking at some weather data, I found that barometric pressure that day was:
Barometric_press = 101.5 kPA
So the calculation for boost would be:
(Loadcalc – Barometric_press) * 0.145037738
So this would be:
(Loadcalc – 101.5) * 0.145037738
Is this correct, or are there other parameters that affect the load and can’t be treated directly as kPa?
Old Aug 13, 2007 | 07:42 AM
lemmonhead's Avatar
use 2-byte load to be more accurate. do a search for it.
Old Aug 13, 2007 | 09:28 AM
Pd1's Avatar
Pd1
I don't think you can reliably make the conversion from Load to PSI of boost, especially if there's an aftermarket intake involved. As the previous poster said, log 2-byte load if you want to know where the ECU is looking in the timing/fuel maps. If you want to log boost, buy a MAP sensor that you can log via EvoScan, or just buy a JDM MAP sensor from mrfred and replace your stocker with it. It will log up to 33psi for you. No need to do any fancy math to figure out your boost. :-)
Old Aug 13, 2007 | 09:38 AM
cladden's Avatar
If I use the JDM map sensor, is there a need to keep the stock MAF sensor?
Old Aug 13, 2007 | 09:41 AM
chrisw's Avatar
yes
Old Aug 14, 2007 | 04:12 PM
cladden's Avatar
Thanks for the 2-byte loadcalc suggestions.
If anyone is interested, here is a completely stock EVO datalog,
17PSI max,
Seem like PSI is close?
Old Aug 14, 2007 | 06:04 PM
mrfred's Avatar
Originally Posted by cladden
17PSI max,
Its definitely possible to get close, but there will always be an uncertainty of something like +/- 2 psi. Just depends on what's good enough for you.
Old Aug 17, 2007 | 07:52 AM
Jeff_Jeske's Avatar
^ That would be about as accurate as most boost gauges.
But doesn't load change with weight?
Someone with the JDM MAP sensor should compare the output to the calculated routine.
Old Aug 17, 2007 | 08:44 AM
TouringBubble's Avatar
Actual engine load would change with weight, but not the load% value used by the ECU.
Old Aug 17, 2007 | 02:22 PM
lemmonhead's Avatar
its kinda like in humans diet. you can calculate how much calories you intake, and know it takes 3500 calories to gain 1 lb. But it still will be off by 2-3 lbs.
Old Aug 18, 2007 | 09:42 AM
cladden's Avatar
So, the stock MAF sensor is mostly calculating the load.
What load is the MAF sensor good up to?
Old Aug 18, 2007 | 10:30 AM
I don't think the "MAF" sensor has anything to do with load. It reads air flow and temperature. You might be thinking "MAP" sensor which is completely different. I'm not exactly sure what the stock MAP (MDP technically) measures or even does ...
Old Aug 19, 2007 | 09:27 AM
cladden's Avatar
I have read in another post that the U.S. version of the EVO comes with a map sensor that reads only up to 2 psi?
Here it is,
Originally Posted by mrfred
Intro
USDM Evos have a 1 bar MAP sensor that can only measure up to 2.2 psi of boost. However, the JDM Evo 9 uses a 3 bar MAP sensor that can measure up to 32 psi of boost. The JDM Evo 9 sensor is identical in appearance to the USDM sensor, so it can be easily swapped for the USDM sensor.
So, the load calculation has to be derived from something other than the map sensor above 2.2psi
Old Aug 19, 2007 | 09:50 AM
mrfred's Avatar
Here it is,
Correct. Load is not derived from the MAP sensor. Its derived in part from the MAF sensor reading and rpm.
Old Sep 3, 2007 | 10:20 PM
tephra's Avatar
Guys - quicky..
What is the 2psi MAP for? Whats it's purpose?
