LoadCalc to PSI
Old Sep 3, 2007 | 10:37 PM
mchuang's Avatar
Originally Posted by tephra
Guys - quicky..
What is the 2psi MAP for? Whats it's purpose?
Are you meaning the 2psi above 14.5psi? I think that is the margin of error because i dont think any sensor is exactly at 1bar or 2bar or 3bar. Most can read slightly past but it just wont be guaranteed as accurate as you would be if you stay within the suggested range of operation.
Old Sep 3, 2007 | 10:40 PM
tephra's Avatar
no - I mean what is the MAP sensors purpose on the Evo - given that we have a MAF
Old Sep 3, 2007 | 10:42 PM
mrfred's Avatar
Guys - quicky..
Mainly EGR check.
Old Sep 3, 2007 | 10:44 PM
codgi's Avatar
Originally Posted by mrfred
Correct. Load is not derived from the MAP sensor. Its derived in part from the MAF sensor reading and rpm.
Which would explain why the same load at different rpm can mean different amounts of boost. The above calculation would then need to take rpm into effect to accurately predict boost.
isnake
Apr 9, 2017 02:01 AM
silverstream
Aug 20, 2011 05:16 PM
racer135
Apr 17, 2008 06:36 AM
jcsbanks
Jan 4, 2008 08:56 AM
