Got my WB hooked up and I got a few Qs (Mitsulogger)
Got my WB hooked up and I got a few Qs (Mitsulogger probs)
I installed my AEM UEGO today, and updated my rom (96940011) with the 2 byte load mod. I added the additional info in the xml file for Mitsulogger, and I can see 2 byte Load in the logging window. But, when I go to start logging, Mitsulogger just stops. It appears that the WB is connected and working in the small WB logging window, but nothing in the main one. I check the log file, and it is only a couple seconds.
What else do I need to do to get Mitsulogger working? I uninstalled the old version, and reinstalled the new one. Am I missing something? I cant seem to find any info for setting it up on this site or Aktivematrix.
Im getting AFRs of 10.5 at spoolup tapering to 10.0 at redline. And Im wanting to get into this thing and start tweaking.
Thx
CB
Thx
CB
Bump
This morning I uninstalled EcuFlash, and reinstalled all of the drivers for the cable. Now it is giving me an error that says it cant connect to Openport right after it starts logging.
edit: I also did the "CEL flash on knock" mod, and its defintely showing some knock. And probably pulling timing/adding fuel. I just cant get the darn thing to log now...
The problems Im experiencing are only with Mitsulogger V1.6 beta 3. V1.5 works fine, but it doesnt support the AEM.
Has anyone else run into this problem?
EDIT for the 100 post count! WOOT!
Thanks for your input. Ive searched, and searched, and searched, here and aktive matrix. Am I missing something in your quick and pointless post? Ive read through the post.
Are you reading what Ive posted? v1.5 works, v1.6 doesnt with or without the WB connected, with or without modded roms or xml files. I dont see why one version works, but the other doesnt. Are there some files in the registry that I need to clear out?
Its pretty ridiculous when someone that actually reads, searches and understands most of whats posted gets a problem; and some of you guys are so quick to jump in and say SEARCH! I consider myself a troll, in that I sit here and read, and only post when I absolutely cant figure something out.
All helpful advice is very much appreciated. Thanks
assuming you are using a USB to serial adapter, it sounds like you have issues there.
If you are using something like this to connect the WB to the laptop, you need to make sure that the USB/serial adaptor is using a different chipset than the tatrix cable.
If the USB serial cable is using the FTDI chipset then you can have conflicts. I don't know how to resolve those issues (I have a serial port on my laptop) then you will need to search again.
Also try searching on www.openecu.org
I have a serial port on my laptop as well, and can hook up through hyperterminal.
My problem is not with my WB. I guess the title of this thread should say "Cant get Mitsulogger v1.6 beta 3 working" Like I said above, Ive tried unhooking the WB, using my unmodified rom, using unmodified xml files for mitsulogger, updated drivers, unistalled/reinstalled ECUFlash. I have version 1.5 (which does not support AEM wb), and works perfectly. But the newest version will not log anything.
my fault for starting a thread in the wrong direction.
