Wierd issue
Old Aug 23, 2007 | 02:46 PM
sabastian458's Avatar
That is true. Look in the glove box, on the left side (between the actual box and the dash assy) THere should be a sticker with a part number and a bar code. Get me that part number and the serial number below it and I can get you the correct code for the car.
If you have some one else's computer, get me the same info but off their car.
Old Aug 23, 2007 | 02:53 PM
Speed Corps's Avatar
Former Vendor
This off of my car,
TAKATA
MH185260
F14011689
Old Aug 23, 2007 | 03:02 PM
Former Vendor
I pulled the codes.
p0603 PCM Keep alive KAM
P0069 Map Correlation
Old Aug 23, 2007 | 03:20 PM
RnRjames's Avatar
Give Me The Vin I Will Give You The Code I Work For Mitsu
Old Aug 23, 2007 | 03:22 PM
Former Vendor
Vin: JA3AH86D34U070577
Old Aug 23, 2007 | 03:26 PM
RnRjames's Avatar
incorrect vin i already tries vin does not exist recheck it
Old Aug 23, 2007 | 03:34 PM
that vin is fine. It pulls up the evo
RnRjames's Avatar
i got it it is the correct vin give me one minute
Old Aug 23, 2007 | 03:36 PM
Originally Posted by Speed Corps
This off of my car,
TAKATA
MH185260
F14011689
Where did this come from? Please give detailed description of location
Old Aug 23, 2007 | 03:37 PM
Former Vendor
Yes, I double checked the VIN. I'm kinda worried about the PCM Keep Alive Memory code.
You wont beable to pull HIS Immobilizer code off the superscreen without the serial or part numbers.
Former Vendor
It was a bar code sticker behind the glove box, you had to look up. There wasn't one on the left.
Old Aug 23, 2007 | 03:39 PM
The one I need is kinda behind the left side of the box, almost cant see it with the box in. THe serial number should start with a 9A then 6 digits after that
Old Aug 23, 2007 | 03:52 PM
RnRjames's Avatar
okay the codes i believe some where along the way the rom was deleted. you need to take it to mitsu or give us the numbers also with the key code i believe it is possible to obtain the imm code
Old Aug 23, 2007 | 03:55 PM
RnRjames's Avatar
would the code 7315 work cause thats the master code with the mut tool that reprograms keys
