gm solenoid strange boost?
Old Sep 28, 2007 | 12:00 AM
al\lupo's Avatar
Originally Posted by ShamelessCookie
290 load is about 26psi on the stock turbo.
I'd suggest a couple things... first, a JDM MAP sensor. This will allow precise boost logging, as well as give you the option to use mrfred's true EBC (ie., you dial in a boost level and the JDM MAP reports back to ECU)
Using pump gas only, 26psi is pushing it... I was able to spike 26-27psi on pump with no knock, but honestly I'd rather not run more than 25psi on stock internals with only pump gas.
I was thinking about JDM MAP, but EDM IX GSR does not have any MAP, so I should drill the intake.
I didn't said that the car lives with 100 octane, always. No more than 1-2 knocks. AFR little rich for now, but I'm working on boost.
The load goes to 285-290 for 0.2 seconds in the logs (3300 rpm), than 260 tapering to 210 at 7500. Can this be safe? I see logs with 245 load at redline with stock turbo and internals...
Old Sep 28, 2007 | 12:07 AM
Erik@MIL.SPEC's Avatar
This might be a dumb question, but it doesn't even have an MDP sensor?
Old Sep 29, 2007 | 08:08 AM
al\lupo's Avatar
AFAIK, no.
PPM
Apr 2, 2015 09:35 AM
AIK
Jan 23, 2009 05:51 PM
sharkm87
Nov 20, 2008 09:37 AM
racer135
May 14, 2008 07:06 PM
Shadowpriest
May 5, 2008 12:39 PM
