BEC and WGDC Change %
Old Nov 17, 2008 | 03:36 AM
sharkm87's Avatar
for some reason, I cannot get these two fields to work, or they work very well and my problem is elsewhere.
when logging in evoscan, my wgdc change stays at 0, but also my BEC stays at -3....now at -3 in my table it is set to 0.
however, my jdm map is reading between 26 - 27 psi, so i let off...
i've recently installed the gm 3 port and trying to get this thing working right...its wierd the first dayi had the BEC all at 0 and adjusted just the wgdc and i was at 25 psi..next morning it was off, so i started adjusting the BEC tables....
now I went threw step by step and can't figure out why it stays reading at -3...and wgdcc 0.
my understanding is what i place in my baseling boost table, which i have set to 24.5 is what i should be seeing in my jdm map......my boost adder is set to 14.7
any help?....also i'm still on ecu flash 1.34, evoscan 2.1
Old Nov 17, 2008 | 06:41 AM
sharkm87's Avatar
up up and away
Old Nov 17, 2008 | 08:37 AM
mplspilot's Avatar
Double check what you have in boost adder and base line boost tables. It sounds like they may be off — higher that what they should be.
Also double check the definitions and the values you added for your JDM MAP in your ROM.
Old Nov 17, 2008 | 08:57 AM
sharkm87's Avatar
boost adder 14.5 and in my boost tables its at 24.6
Old Nov 17, 2008 | 09:02 AM
tnt1106's Avatar
what ele are you at? close to sea level?
Old Nov 17, 2008 | 09:03 AM
sharkm87's Avatar
yea jersey is sea level...i'm like 92 feet above
Old Nov 17, 2008 | 09:05 AM
sharkm87's Avatar
my understanding is boost level is my atmostpheric, and whatever i set in desiered is what i see, and also its #1 correct??? i've seen post of people altering the other tables.
Old Nov 17, 2008 | 09:06 AM
tnt1106's Avatar
i have had some random spikes with my psi based as well. this weekend at the track on e85, with WGDC pulled down and car set for "25" psi i hit 27+ more than a few times.. its odd. plus boost error showed it adding boost to get to that lvl ..
oh this was on alt map also, perhaps there is a bug controlling boost. about to swap gas / e85 maps then see what it does
ok foot in mouth, i have to retrack that as looking back my guage showed 28max, jdm right where it should have been jsut above 26psi.. here is a pic
Old Nov 17, 2008 | 09:08 AM
sharkm87's Avatar
but in my situation, i have it set 24.5....my jdm map is showing 27, even 28.....my bec stays at -3...causing the correction to stay at 0
Old Nov 17, 2008 | 09:21 AM
tnt1106's Avatar
i would set all 3 baseline boost maps to the same values. and yes boost adder is up to your atmosperic if you want 24.6psi or lower. then the baseline boost values should be what your jdm logs.
Old Nov 17, 2008 | 09:23 AM
tnt1106's Avatar
something not set up right in rom, or leak maybe? sounds odd
Old Nov 17, 2008 | 09:41 AM
sharkm87's Avatar
i will do that, however something sitll may be wrong if i'm goin above my target and its saying -3...i still dont understand that.
Old Nov 17, 2008 | 09:42 AM
mplspilot's Avatar
Set all 4 tables with same values.
Old Nov 17, 2008 | 10:14 AM
sharkm87's Avatar
ok will do
Old Nov 17, 2008 | 02:59 PM
sharkm87's Avatar
ok i made them all the same but its still the same problem..
heres something i have a question on...when seting the boost desired.....what is checkin it against the jdm map sensor..maybe thats my issue.....
