Stalling with AC on issue
Old Sep 26, 2007 | 09:23 PM
  #31
mplspilot's Avatar
Originally Posted by ThEHiTMaN
my idle is at -70ish ac off and -50 to -60ish with it on... the step iscv helped but u can not make quick gas and clutch in or the car is fawkt. my idle also goes up to 2k sometimes with the ac on. basically wit the ac on thre car has a mind of its own.. lol its like a box of chocolate u never know what ur going to get...those readings are from my greddy edc and I am not sure what they represent... it is also a digital boost guage... I get the positive numbers like 235 means 23.5psi but -70 means? who knows.... when the car dies I have seen it go down to -28...
That's funny
No separate ignition for AC.
Old Sep 26, 2007 | 09:51 PM
  #32
ThEHiTMaN's Avatar
wait until the exedy twin goes in it should idle top notch! now it idles at 2k with the ac on much Better then 200rpm... lol seems worse in high humidity....
Old Sep 27, 2007 | 08:40 AM
  #33
20psiMR's Avatar
I had this problem since the first day I bought my car. 10 miles on odo with 0 mods and mine would stumble with ac on and coming to a stop with rpms dropping. Idle for me is fine, its just that light cruise when you take the car out of gear and apply the brakes, thats when it stalls.
Old Oct 1, 2007 | 01:21 PM
  #34
duracell55's Avatar
any fix to this I have the same problem too! I also have an Exedy twin and Cosi cams, still having the same problem when I went from ECU to AEM
Old Oct 1, 2007 | 02:29 PM
  #35
ThEHiTMaN's Avatar
I have noticed that it does not do it if before you put the clutch in and take it out of gear let it build vaccumme and then take it out of gear.... For instances if you are comming to a light don't just put the cutch in right after your foot comes of the gas... coast up to the light in maybe 3rd or 2nd for a few seconds and then put the clutch in it really helps.
Old Oct 24, 2007 | 08:20 PM
  #36
broddey's Avatar
bump for updates!
Old Feb 21, 2008 | 08:20 PM
  #37
gt420hp's Avatar
Same exact problems, when the car was stage 1, and continues with the car at stage 5. I see RPM's drop below 500 when I am coasting to stop light, or pulling into my garage and stopping quickly in the front of the garage. The car almost stalls, sometimes the CEL flashes.
I had this same issue with my 2004 EVO 8 also, but that was with the twin disk, so I always figured it was the clutch causing issues.
The trix to downshift before you get to the light instead of just popping out of gear does work....
I notice it happens a majority of the time when going up an incline or hill. Never seen the problem going downhill.
I agree it must be a vacuum issue, because braking is always involved.
Old Feb 26, 2008 | 02:10 PM
  #38
kayman's Avatar
I too get the problem ... my only power mods are a TBE (stock cat) / Panel Filter / EBC... also happens when reversing ... if I reverse a little bit then clutch in it goes to a close stall (happens nearly every day when getting into my driveway). My CEL doesnt come on but you can see the car struggling before it bumps the throttle back up.
Old Feb 26, 2008 | 02:28 PM
  #39
waitin4d's Avatar
So I guess I wasn't the only one with the problem... I hope someone comes up with a fix.
Old Feb 26, 2008 | 03:51 PM
  #40
kayman's Avatar
Ohh and I have a excedy sports organic clutch as well ... however the problem was happening before the clutch replacement.
Old Feb 28, 2008 | 10:13 AM
  #41
waitin4d's Avatar
It was fine with my Exedy Hyper single
For me the problem started happening after the cam and intake install.... and a tune.
Old Mar 18, 2008 | 01:40 PM
  #42
03v8slayer's Avatar
I am haveing the same problem has any one found a fix yet? This sounds like a lot of people have the same problem. Mine started after a clutch install be the dealership
Old Jul 15, 2008 | 08:38 PM
  #43
mitsuevo803's Avatar
bump for more updates. just bought a new iac putting that in later this week...hopefully fixes it
Old Apr 29, 2010 | 09:29 AM
  #44
tnt1106's Avatar
bump to fix for this
Old May 2, 2010 | 04:29 PM
  #45
shrty10135's Avatar
I just got my evo 9 mr and it has exedy twin plate, ams tbe, 272 cams. and i stalled going down a hill when i pushed the clutch in with the AC on. WE REALLY NEED A FIX FOR THIS!!! HELP!!!!! please, anyone ?
