how-to: ECU-based direct boost control
Old Mar 15, 2009 | 10:04 PM
  #616
fostytou's Avatar
EvoM Community Team
Originally Posted by nano
I've been trying to get this dialed into my car for the last couple of days. WOT 3rd gear pull works like a charm, BoostError is ~0.0-0.5 all the way through the boost curve to redline.
5th gear is a different story though, if im on the freeway at ~5k and I go WOT the boost will overshoot and BEC doesnt take affect. My target is 21psi but it will overshoot to 25+ on a rolling 5th gear pull. I have included my tables, any pointers would be awesome...I've tried lowering the WGDC but then it becomes too low for boosting in other gears. This is for a bbk on 91, no meth yet so keeping boost reasonably safe.
Originally Posted by fjo_newport
Try changing the max upward correction vs TPS to be something small and only at a TPS of 100%, zero out the rest. Also carry that 55%WGDC back to like 2000 RPMs.
I personally prefer to let the correction v tps table remain stock after I'm done tuning boost.
You are way to high of a WGDC too early. I can see 25 PSI by 2750 on my stock turbo in 5th gear. V6 now has the ability to do gear based boost control, so that helped immensely. You will either have to lower your duty cycle and expected boost dramatically at 2750 and 3k (and maybe 3.5) or just be smart enough to not mash the pedal all the way in 5th until you can get gear based control.
Notice 5th gear in the tables here... I've even lowered it since this pic was posted...
https://www.evolutionm.net/forums/6808179-post153.html
Old Mar 16, 2009 | 11:15 AM
  #617
nano's Avatar
I appreciate the info frosty. I have been eying tephra v6 since he released it but been waiting till its fully tested to give it a go. Seems like no one has had a problem with 88590015 so I may switch over tonight and log tmrw morning on my way to work. Time to give gear based boost control a try
Old Mar 16, 2009 | 01:26 PM
  #618
dan l's Avatar
Originally Posted by ExViTermini
It'd be reallly superb to have it set as a PSI based cut, and to have higher than the 319 equivalent. Would really be superb if there could be an alternate one as well for the alternate maps, but I'm sure thats quite involved..
Many people run the mitsu 3 bar because its easy to do and plug and play. If you go with PSI cut you are limited to about 29 psi. People like me can and do run 29psi so I'd want my boost cut at 35psi (I wouldn't use it, but for arguments sake). Thus load based is still a better option because you aren't capping yourself with the mechanical limit of a pressure sensor.
Old Mar 16, 2009 | 02:05 PM
  #619
justboosted02's Avatar
omni 4 bar
Old Mar 16, 2009 | 03:20 PM
  #620
Inprogress's Avatar
mrfred,
What is the correction interval for? I had it set to 3, I just wanted to know what it helped with and what not?
Also, you're suggesting, if we have tuned everything successfully until step 3, we can try your settings for step 4 and 5?
Old Mar 16, 2009 | 03:42 PM
  #621
ExViTermini's Avatar
Understandable, just keep in mind multiple people have logged 33psi with the mitsu sensor, so there would still be a little headroom. Regardless I'm running a 3.5bar sensor, so I have a little more room to play, in which I intend to do
Old Mar 16, 2009 | 06:28 PM
  #622
another question for the masses, if the map sensor fails, obviously it will set a CEL, but what happens with the boost control?
Old Mar 16, 2009 | 06:33 PM
  #623
tephra's Avatar
if the sensor fails and you get a 0psi back, then so long as your TBEC doesn't have anything in the "underboost" then it wont add any wgdc - so it will just follow the baseline wgdc...
I think that's correct..
Old Mar 16, 2009 | 06:41 PM
  #624
what if it fails and you get no voltage back..?
Old Mar 16, 2009 | 06:42 PM
  #625
tephra's Avatar
0 volts = 0 psi...
so basically the TBEC lookup will happen and it will HIT the top cell... for which you should have 0% WGDC correction...
Old Mar 16, 2009 | 09:31 PM
  #626
mplspilot's Avatar
Here are my tables FWIW. This is on the stock 9.8 VIII turbo. :
3rd gear:
4th:
Old Mar 16, 2009 | 09:52 PM
  #627
fostytou's Avatar
EvoM Community Team
I personally don't agree with the tuning method used in your tables at all.
What type of fuel are you running on this setup? I'd say your settings are a little too high for E85 and a little to low for Q16.
My recommendations if you are having troubles - Change all but the top -3.1 psi to what it was and correction to 0. Change th bottoms back to normal and just make them all -3 adjustment.
Less WGDC at 2500 and even less at 2750.
Change the baseline boost table to reflect what boost you actually expect at that RPM, especially in the lower RPM. Change the scaling so you can easily visualize what you are actually aiming for.
Old Mar 16, 2009 | 10:27 PM
  #628
mplspilot's Avatar
^ I'm not having any problems. This is my example of how these can be tuned. 0.4 psi steps are a waste of time in my opinion. Correction lags behind boost anyway with this method of boost control, so there is no need for fine psi resolution. This is easier and works fine as you can see in the screenshots.
Old Mar 16, 2009 | 11:08 PM
  #629
Inprogress's Avatar
Originally Posted by Inprogress
mrfred,
Any takers?
Old Mar 16, 2009 | 11:28 PM
  #630
mplspilot's Avatar
The lower the number the more often the boost error is checked and the necessary adjustment to WGDC is made. I think the lowest that works is 2. 1 should work with Tephra's v6, afaik.
If you want it checked and adjusted often, use smaller numbers in error correction.
More exact numbers in ms are posted somewhere in this thread i think. Just search.
