TephraMOD V6 - testing!
Old Mar 13, 2009 | 08:04 AM
  #151
fostytou's Avatar
EvoM Community Team
https://www.evolutionm.net/forums/6804747-post1.html
Problem possibly related to V6, but unlikely...
Old Mar 13, 2009 | 07:03 PM
  #152
Jack_of_Trades's Avatar
Subscribed. I'll try to catch up on the on-going mods and help however I can with the map switching/failsafing.
Old Mar 14, 2009 | 12:35 AM
  #153
fostytou's Avatar
EvoM Community Team
Originally Posted by tephra
Quote:
In the table where you set the gear for the rpm/mph can you just change the 6 to a 5 (IE make both of the top two left column numbers 5)so that you don't have to set the 6 values the same as 5? .... or is that and the boost header row only pointing to the same number that displays 6? Would it be easier/work to just set the rpm/mph to 0 for gear 6? (it seemed like I was getting a tiny bit of confusion between 5 and 6 while logging).
Can you post up your gear table for the 5spd? just leave the 6th map as is for the time being... I need to see what the other values are
Sorry Tephra, I don't think this one ever got answered
I'm currently using this, it was surprisingly close the the 6 speed. If I just change the 25 in RPM/KPH to a 0 will it not be able to calculate 6th and only read 5th?
Please note this is just an initial setup with V6, but I have a feeling it is pretty close
Old Mar 14, 2009 | 12:55 AM
  #154
dude's Avatar
Any love for the 2003 Evo's in the pipes Tephra? I know you're still working the bugs out on the other ROMs first, but I'm sure there are a bunch of 9471xxxx guys that would be willing to test for you...
Any reason why this series ROM gives you more grief that others? Do you need a clean stock ROM???
Old Mar 14, 2009 | 01:39 AM
  #155
tephra's Avatar
fosty - you have two choices:
1) set the 6spd to the same ratio as the 5spd (ie 28 in ure picture) - then copy the 5 column to 6
2) make the 6spd something really low - like 5, ie it will never happen... then u dont have to worry about the 6 column
Old Mar 14, 2009 | 09:42 AM
  #156
fostytou's Avatar
EvoM Community Team
I had a feeling #2 was the best answer Anything to save a few writes.
BTW, these numbers were taken as an average from revving ~2k-4k in each gear and excluding outliers. does the RPM/KPH change much from 2k to 7k? If so I'll go back and do a full pull for each gear
Old Mar 14, 2009 | 01:59 PM
  #157
nonschlont's Avatar
ok I was having an issue, but hopefully have found my issues. Thanks fostytou! heres the link.
https://www.evolutionm.net/forums/ec...hra-v-6-a.html
I missed some things in the last couple days I see.
when I first had the issue, I didnt think it was tephra related, (reason it wasnt posted in here) but seems there are a few maps I didnt understand, and left stock, but need to be tuned...
So I have made these changes to be similar to what fostyyou has posted...
So let me see if I understand this now... There are 2 methods, but this is the better of the two?
"rpm/speed to gear" table
25 - 6 just set the 25 to something like 5, so this gear wont be referenced?
48 - 5
51 - 4
54 - 3
73 - 2
105 - 1
1802 - 0
TIA
Old Mar 14, 2009 | 06:16 PM
  #158
tephra's Avatar
Fosty - the gear ratio should remain roughly the same over a pull... u can log it and see it changing ever so slightly...
Nonschlont - if you have a 5spd box then set the ratio for the 6th gear to like 1 or 2... something that's never going to occur during normal driving..
Old Mar 14, 2009 | 08:52 PM
  #159
supersnow's Avatar
Do we need to adjust the gear/speed table if we have a stock set up? (235/45/17 on a 9)
Old Mar 14, 2009 | 08:54 PM
  #160
tephra's Avatar
no just verify the logged gear is correct - see 1st post for evoscan xml for the gear...
Old Mar 14, 2009 | 08:56 PM
  #161
supersnow's Avatar
you are fast!
Thanks!
Old Mar 14, 2009 | 10:35 PM
  #162
nonschlont's Avatar
Old Mar 15, 2009 | 10:23 AM
  #163
eTiLiKo's Avatar
Have you included the 30hz BCS frequency routine in V6 tephra?
Old Mar 15, 2009 | 01:31 PM
  #164
dan l's Avatar
I didn't have a chance to read all 11 pages so far, but I'd like to mention something with respect to the rpm vs speed calibration for boost maps. If you are slipping your clutch the engine won't stay locked to the drivetrain and your numbers will change. It should be noted however that clutches can and do slip under normal conditions but if it gets excessive it can cause problems.
Old Mar 15, 2009 | 03:31 PM
  #165
tephra's Avatar
hey Dan - yep, but luckily that will only be 1st or 2nd gear, and since the ratio's are so far apart it probably wont matter.
be interested to see the gear log of a slip launch thou
eTiLiko - yes, i dont think its 30hz thou... but yes higher resolution for the wgdc
