TephraMOD V6 - testing!
Old Mar 19, 2009 | 03:55 PM
  #196
nonschlont's Avatar
Originally Posted by tephra
Phil -
1) regular evoscan already contains a "gear", this is my fault, just remove the original one and replace with mine...
2) gear should be using MUT40 - so double check that MUT40 is programmed correctly, should be 0x8447
Thanks Dave. Will do. Im thinking I had 0x8447 @ 40, before I had copied my MUT table over (when I left your MUT table) and had the cell come up, and I flashed back, right away. And never changed 40 back to 0x8447...
Any ideas why rpm/speed to gear isnt logging? I believe the values in 42, 43 were already there... 6A9B, 6A9F (not infront of my comp.) I need to go over my/your MUT table, but I think these were the same as mine... will check it out Are these the correct values for 42, 43 ( 6A9B, 6A9F )?
Thanks again Dave, not only is this the ish, but you have been a big help as well!
Edit: Im a mess! I think my issue was, I had 0x8417, not 0x8447...
Old Mar 19, 2009 | 06:08 PM
  #197
tephra's Avatar
just look at the MUT ID's evoscan uses (for gear+whatever) and make sure those MUT's contain the information i programmed in originally.
Old Mar 19, 2009 | 06:24 PM
  #198
nonschlont's Avatar
I need to stop doing this so late... lol I should be good to go now.
I feel like a defo boarding the lil yellow bus...
cheers
Old Mar 20, 2009 | 02:21 AM
  #199
mlocatel's Avatar
Hello Tephra
just one question: the MUT request to log the alternative Map switch is still the 83? Was it included in your MUT Table?
I'm done with testing on normal maps: everything is fine (after ~2000km). Now I'll be running on alternate maps to check that everything is fine as well.
thanks
mlocatel
Old Mar 20, 2009 | 04:01 AM
  #200
tephra's Avatar
stock MUT83 should still work...
MUT83 is just the voltage going into the ADC...
Old Mar 20, 2009 | 05:32 AM
  #201
mlocatel's Avatar
There were another MUT that was either 255 or 0
Which one is it?
Old Mar 20, 2009 | 11:21 AM
  #202
nonschlont's Avatar
Im getting there... :updown:
OK Today I went through all the gears, and I now have Gear working properly, MAT was logging 32 throughout all gears (entire pull). Is this reading correctly? The reason I ask, is, that my rpm speed ratio is reading
1st = .385
2nd = .275
3rd = .192
4th = .137
5th = .11 I dont think this reading correctly? I dont see any decimal points in the rpm/speed to gear table.
TIA
Old Mar 20, 2009 | 12:13 PM
  #203
fostytou's Avatar
EvoM Community Team
If you don't have a MAT sensor wired in then you will not see any data related to that particular item.
Looks like something is wrong with your MUT still. Download the rom from the first link and copy the MUT values from MUT 42 and 43. It is working for everyone else, so if you use those MUT values and the evoscan formula from post 1 there is no way that it can go wrong.
Old Mar 20, 2009 | 12:25 PM
  #204
fostytou's Avatar
EvoM Community Team
Which one is it?
I can't remember if these are correct (and don't know if the activation one still works)
MUT00 with 8425 and MU01 with 8929.
Code:
<DataListItem DataLog="N" Color="" Display="ALT MAP Activation" LogReference="AltMapActive" RequestID="00" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="1" Notes="Alt Map Activation. 0= Standard Maps 3= Alt Maps" Priority="1" Visible="False" />
<DataListItem DataLog="N" Color="" Display="ALT Map Input Voltage" LogReference="AltMapVoltage" RequestID="01" Eval="(x/256)*5" Unit="Vdc" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="15" ChartMin="0" ChartMax="15" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Mar 20, 2009 | 12:27 PM
  #205
justboosted02's Avatar
94170015?
Old Mar 20, 2009 | 12:59 PM
  #206
nonschlont's Avatar
so I have gear, and 1byte working correctly.
40 = 8447 / 41 = 840B / 42 = 8448 / 43 = 8449 and 44 = 8443
MAT, I need a sensor... oops.
And rpm speed ratio isnt logging correctly...
can you post up the formula for "rpm speed ratio" so I can compare it w/ mine later?
Old Mar 20, 2009 | 01:19 PM
  #207
fostytou's Avatar
EvoM Community Team
It is in the first post, along with the ROM to compare to.
Old Mar 20, 2009 | 02:14 PM
  #208
nonschlont's Avatar
I have copy / pasted the entire def. and made no changes to it... So it should be the same... And I have double/triple checked my MUT table now....
Do you need to have gm/s se t up in the MUT table, and could this have something to do w/ rpm speed ratio not logging?
I have left 00, 01, 02, 03, 04,05 in my MUT table as the 2bytes, but changed 40, 41, 42, 43, 44, to what is in Tephras rom, and made sure the request id's in evoscan match up...
Nothing like feeling like a newb on a daily basis... I guess thats cause I am 1...
Old Mar 20, 2009 | 05:32 PM
  #209
tephra's Avatar
Which one is it?
MUT83 is the voltage on the ADC input into the ECU. So if you supply 4v, MUT83 will read 204ish...
Old Mar 20, 2009 | 05:33 PM
  #210
tephra's Avatar
Phil - What is the MUT request ID that RPM/SPEED ratio is using?
