TephraMOD V6 - testing!
Old Mar 20, 2009 | 10:44 PM
  #211
nonschlont's Avatar
Originally Posted by tephra
Phil - What is the MUT request ID that RPM/SPEED ratio is using?
It shows 42, 43 in the .xml, but only 42 when you (r) click, edit
Old Mar 20, 2009 | 10:56 PM
  #212
tephra's Avatar
and what does your MUT42 and 43 show?
Old Mar 20, 2009 | 11:19 PM
  #213
nonschlont's Avatar
8448, 8449
Old Mar 20, 2009 | 11:24 PM
  #214
tephra's Avatar
should be right.
whats the formula in evoscan?
post up a short log of you doing a 1st/2nd/3rd (just normal driving, not pull)
Old Mar 20, 2009 | 11:39 PM
  #215
nonschlont's Avatar
should be right.
x/36.37
~60% tps
Old Mar 20, 2009 | 11:42 PM
  #216
tephra's Avatar
phil - can you email me that log?
just zip up the .csv and let me know what line number to start looking at.
gear is coming out right isn't it?
maybe its an evoscan version thing?!?!
Old Mar 20, 2009 | 11:54 PM
  #217
nonschlont's Avatar
sent. Yes gear is working perfectly, so is 1byte load.
Old Mar 21, 2009 | 12:10 AM
  #218
tephra's Avatar
hrmm its like its ignoring the 2nd byte...
any chance you want to try evoscan 2.6b6? or whatever the most recent beta is?
if gear is working correctly for you then u probably dont need the rpm/speed ratio... its mainly meant for ppl with different sized rims or gearboxes..
Old Mar 21, 2009 | 12:41 AM
  #219
nonschlont's Avatar
I do have 18's... Dont I need to log this to get the "rpm/speed to gear" map on point? Im feelin a lil iffy on trying the beta version, especially now that I have eveything else working right now. I know theres some process to get it running. I'll have to read that thread. Maybe I'll be feeling spunky tomorrow...
Old Mar 21, 2009 | 06:36 AM
  #220
tephra's Avatar
u can run both evoscan versions at the same time - 2.6b6 is just an exe copy - so save your current evoscan.exe (so u can run the old version)
Old Mar 21, 2009 | 08:07 AM
  #221
dan l's Avatar
Is anybody having problems when cold starting their car? I though it was a problem with my car but I flashed back to my v5.10 rom and the car is fine. I redid another v6 rom thinking I may have had a corrupted rom and it still won't idle when cold. I'm not again back to v5.10 and all is fine. The problem is the car goes lean (17-18afr) and then the idle stumbles and the car stalls.
1000cc/min injectors
walbro 255
catback exhaust
GM 3-port
JDM map
Old Mar 21, 2009 | 08:44 AM
  #222
fostytou's Avatar
EvoM Community Team
walbro 255
catback exhaust
GM 3-port
JDM map
Didn't happen to flip which maps were pump/E85 did you? I did that the first time I flashed to v6 and forgot to flip my switch. It was a Dur moment.
*slaps forehead*
Old Mar 21, 2009 | 09:10 AM
  #223
dan l's Avatar
It runs fine when warmed up. Like all of a sudden at about 150deg F coolant temps or theirabouts it idles and drives fine.
Old Mar 21, 2009 | 04:16 PM
  #224
tephra's Avatar
V6 includes alternate IPW on startup - which is based on coolant temp...
so it could be something todo with that... did u copy that table properly?
Old Mar 21, 2009 | 04:24 PM
  #225
dan l's Avatar
Yeah, its correct. I'm doing something stupid, just need to find it. No worries.
