How to setup evoscan or data log lab to show correct hp or torque?? please help!!!
How do I setup correction factor in evo scan or data log lab to show correct hp or torque?!? I have 44793 HP!!!! WOW!!! that's in datalog lab.. in evoscan is a little bit lower!!!
I have an EVO IX with stock wheels and Dunlop SP9090 tires!
Use that excel file in the thread I linked to you. All you have to do is copy from your EvoScan log and paste in to the Excel file. It will graph your logged values and the HP/TQ for 3rd or 4th gear.
You may have to re-arrange the values a little in the Excel file because it's set up specifically for Mrfreds logs. I can help you with it if you aren't familiar with Excel.
This calculation reads a little lower than a compared DynoJet pull but it quite close to Mustang Dyno numbers. But, as it's been stated, a road dyno calculation is only good for comparison runs in the same conditions and in the same location. You simply cannot base actual power on the numbers from one of these calculators.
all the data in evoscan logs is pretty confusing, is not ordered aS in the excel file you told me to paste into.. a lot of numbers and , and . How do I copy and paste if it is so mixed??
Wizard_of_Evo
25
Jun 28, 2010 05:50 PM
Wizard_of_Evo
Jul 6, 2004 08:04 AM
i'm kinda new to evoscan..
