PATCH: NLTS + Valet + KnockCEL
Old Oct 18, 2007 | 05:24 PM
  #691
raiceboi697's Avatar
any progress on 96940011?
Old Oct 18, 2007 | 05:43 PM
  #692
tephra's Avatar
96940011? its already up do you mean 96420011? still waiting for a stock ROM for that one I think!
guys I _might_ have an automatic enable security mode in the next release...
I just want to see what happens with this other thread about NLTS problems - it might be a bug which I can put in th next release as well..
Old Oct 18, 2007 | 06:01 PM
  #693
i think i sent it to you that same day...if not tell me where i can find it and ill send it your way. i added the codeing from the 9694 rom as my buddy has that one to mine to get the NLTS tables to show up. they showed up but the NLTS wont engauge....any ideas or are they vechile ROM specific????
Old Oct 18, 2007 | 06:06 PM
  #694
tephra's Avatar
the XML goes with the ROM included in the zip! you can't use one without the other...
anyways I have 1 96420011 ROM, but would like another just to prove the 1 I have is stock...
Old Oct 18, 2007 | 06:09 PM
  #695
oh i only have one sorry...so if i use the rom NLTS should work correct?
Old Oct 18, 2007 | 06:11 PM
  #696
diablo2184's Avatar
damn, i gotta go see which ROM mine takes....
i like this thread though, it stays active
Old Oct 18, 2007 | 10:40 PM
  #697
kayman's Avatar
Is it possible to get the mod done to 88580013 ? I have the stock ROM if needed.
Cheers
Old Oct 18, 2007 | 10:44 PM
  #698
tephra's Avatar
just use 14 kayman - there is stuff all difference between 13 and 14
Old Oct 19, 2007 | 06:51 AM
  #699
are all 04 Roms the same???? or does it have to be close to the one i have..I.E. one number higher or lower in the sequrence?
Old Oct 19, 2007 | 02:46 PM
  #700
NineWorks's Avatar
You might get some more then...
Are the coilovers installed already ?
Keep up the good job, Dave
Old Oct 20, 2007 | 11:41 AM
  #701
JordanS4's Avatar
For some reason I was getting fuel cut when trying to leave a stop light in 1st gear. After an embarrasing fit I finally got it to go. It was set at
900 rpm
100% TPS
30 km/h
I changed it to 90% TPS and 0 km/h and it worked. My pedal engages very high but I don't see why leaving a stop light normally was engaging the fuel cut.
Old Oct 20, 2007 | 12:09 PM
  #702
Jack_of_Trades's Avatar
Odds are good you had your foot slightly resting on the clutch pedal pad. We've all done this and all had these "questions". It always always always end up being user error. Its CRAZY sensitive and a bit tricky to get used to.
Old Oct 20, 2007 | 12:21 PM
  #703
SuPeRNeT's Avatar
The rom that i sent you 96420007, I dont think it is stock, Shiv modifed it for use with the xede.. Can you still mod it?
Old Oct 21, 2007 | 04:14 PM
  #704
kayman's Avatar
Great.. thanks heaps Dave!
EDIT: actually Dave so do I write the 14 data to my 13 ecu will that be alright? Im using the 13 definitions and edited it to show on the 14 as well that all good?
Old Oct 21, 2007 | 09:03 PM
  #705
tephra's Avatar
yep that should be just fine.
also if anyone has a stock 96420007 can they send it too me, I have several different copies of this ROM and they are all different ... I want to post up a stock modded rom
