help asap
Old Oct 3, 2007 | 01:52 PM
26 psi's Avatar
help asap
sorry if this is a repost. if my laptop had a virus could it get into my ecu? the reason i am asking is i went add some timming and such and everything is all messed up.the car will hardly run. i didnt even change anything. i pluged it in and it just started going crazy. i had my wireless card in and the computer it just started opening page after page of websites.
Old Oct 3, 2007 | 04:34 PM
recompile's Avatar
I wouldn't advise flashing your car if your laptop isn't 100%... the last thing you want is to have a partial flash (either because the battery died or blue screened or for whatever reason couldn't finish) and you're stranded with a car that won't run.
It's fixable of course, but it could be a huge inconvenience if you're out somewhere, you go to flash, and the laptop dies... now you're getting a tow.
As far as a virus actually getting into your ECU, that's highly unlikely
Can you describe what kind of problems you're having? Do you have a CEL on ? What are your mods?
Old Oct 3, 2007 | 10:23 PM
moreryce's Avatar
and stop watching ****!! lol
Old Oct 3, 2007 | 10:24 PM
codgi's Avatar
Even if the virus got there (which it could by simply infecting the file to be flashed) it wouldn't be able to do anything. ECU would have a fun time trying to interpret it though .
Either way make sure your computer is working properly before doing the flash.
Old Oct 4, 2007 | 02:29 PM
26 psi's Avatar
the car is running pig rich black smoke and up down idle. no power when i put it in gear and let off the clutch it die's i loaded a fresh install of windows xp on my laptop and no i need to get tunning software again my buddy loaded it on there befor and he dont have it anymore so till the im sol
Old Oct 4, 2007 | 11:18 PM
codgi's Avatar
What are you using to tune? You can download ECUFlash from openecu.org so you can load it yourself.
Old Oct 4, 2007 | 11:20 PM
kstpeter33's Avatar
nothing related to the flash...did you happen to check if one of your IC pipes came off somehow?
Old Oct 5, 2007 | 04:03 AM
recompile's Avatar
+1, if you're running pig rich and can't accelerate, then it's likely a blown IC pipe.
Old Oct 5, 2007 | 09:50 AM
26 psi's Avatar
I NEVER EVEN THOUGHT OF THAT AND THAT WAS THE PROBLEM THANKS
forza22
Jul 10, 2013 06:49 PM
Jedi_Gill
Mar 31, 2009 05:31 AM
skold
Feb 14, 2007 10:56 AM
