Overboost
Old Nov 5, 2007 | 07:52 PM
Celica2EVO's Avatar
Overboost
I was wondering how to turn off the overboost function on the ecu. I hava an aftermarket boost controller set to spike at 23.5psi, however if I go to pass someone and punch it in 5th gear it will spike to 26 psi and overboost. Where it feels like it puts me through a wall and then turns on the SES light. So how to I disable the stock overboost using ECUFlash?
Thank You
Old Nov 5, 2007 | 08:17 PM
codgi's Avatar
If the aftermarket boost controller has been properly installed, then the ECU shouldn't be controlling boost anymore. I would check how the aftermarket boost controller is setup...
Old Nov 5, 2007 | 08:23 PM
Celica2EVO's Avatar
The boost controller is a Hallman Pro RX installed to the WGA and the Turbo Nipple. The car seems to hit a brick wall when it boosts to 25 psi. The code I got was I believe P0234 which is overboost. From what I read, the best way to hook up the MBC is the WG and Turbo nipple.
Old Nov 5, 2007 | 08:33 PM
fitbikedominick's Avatar
i have the same problem but i have mine t'ed off the bov because of my buschur delux ic pipe dosnt have the nipple
Old Nov 5, 2007 | 08:39 PM
Celica2EVO's Avatar
ic pipe? mine has a nipple on the bottom of the turbo and the wg. I dont think it has anything to do with the ic piping. correct me if im wrong!
Old Nov 5, 2007 | 08:44 PM
electricevo's Avatar
try raising the "boost limit" setting higher
Old Nov 5, 2007 | 08:45 PM
nj1266's Avatar
I am not an expert on MBCs, but I believe that you should NOT hook up the MBC to the turbo nipple. That nipple should be capped and not used. One side of the MBC should be connected to the WG and the other side connected to one of the vaccuum hoses coming out of the valve cover on the front end. Again, I am not an expert, but that is thw way I remember it being done.
Old Nov 5, 2007 | 09:36 PM
Evo_Jay's Avatar
The boost cut still works when a MBC or EBC is used.
Old Nov 5, 2007 | 09:37 PM
Evo_Jay's Avatar
+1
Old Nov 5, 2007 | 10:08 PM
codgi's Avatar
Yes that is true (hitting the wall) but he still has to control that spike to 26 psi which is what causes it to kick in in the first place. If he solves that, then the limits don't have to be raised.
Old Nov 6, 2007 | 06:24 AM
C6C6CH3vo's Avatar
First, keep the plumbing to the WGA tight with decent tubing. Is your WGA stock with stock preload? This will limit the spike
Then set your boost limit in EcuFlash to 319% accross the rpm and boost cut delay timer to 1000ms. This will keep the car from hitting fuel cut
Old Nov 6, 2007 | 06:40 AM
EvoBroMA's Avatar
he should be fixing his boost problem not disabling the boost limiting system.
Old Nov 6, 2007 | 07:00 AM
MR Turco's Avatar
Why would you do it this way and not use the compressor nipple?
Old Nov 6, 2007 | 07:13 AM
C6C6CH3vo's Avatar
Why not fix the boost problem and limiting both as I proposed? Ever hit fuel cut under stock boost settings?
Psi spikes are fromWGA not getting the control air in time which is easily fixed by reconfiguring the plumbing that drives it. Preload and aftermarket WGA can cause it too.
Old Nov 6, 2007 | 07:35 AM
MR Turco's Avatar
See this is why i WOULD use the compressor nipple. Because there is a pressure drop from the turbo to the intake mani, i would use the higher pressure coming from the turbo to control boost rather then the manifold to even more avoid overboosting.
