Anti-Lag option.
Old Dec 6, 2007 | 11:33 PM
s10v8's Avatar
Anti-Lag option.
In ECUFlash there is an option for anti-lag.
I was curious as to how the car determines when to use the anti lag map? And If i set this up will it be on all the time, and will i have to make two maps. one with anti lag for track use and one without for street use?
Any help is appreciated!
Old Dec 6, 2007 | 11:43 PM
s10v8's Avatar
Never mind. I searched and got answers.
Guess ill have to go ecu+
Old Dec 6, 2007 | 11:59 PM
BarryC's Avatar
HMMMM
this would be a great little project for Tephra,
use a spare input to switch on and off Antilag, like the Ecutek,
Old Dec 7, 2007 | 12:02 AM
06rs_power's Avatar
its been along time since i have gotten to drive a car with anti-lag...i miss it, winter project maybe?
Old Dec 7, 2007 | 03:16 AM
hfalex's Avatar
wish list for xmas!!!
Old Dec 7, 2007 | 09:20 AM
honki24's Avatar
Ecu+ Ftw!
Old Dec 7, 2007 | 03:39 PM
mrfred's Avatar
Originally Posted by BarryC
HMMMM
There is no anti-lag hardware or ROM code on US cars. Only possible anti-lag is what can be had by retarding the timing.
Old Dec 10, 2007 | 11:12 AM
toovira's Avatar
Throttle Position Sensor.
Old Dec 10, 2007 | 03:53 PM
tephra's Avatar
^ random comment :P
the reason why I haven't played with oldskool antilag (retard timing + dump fuel) is it's bad for the turbo, but also bad for the cat
Old Dec 10, 2007 | 04:00 PM
dudical26's Avatar
Originally Posted by tephra
^ random comment :P
Do you really still run a cat?
Old Dec 10, 2007 | 06:41 PM
tephra's Avatar
yep... big fines in australia for not running a cat...
and really there is no reason not to run a cat - other than not being able to antilag
Old Dec 18, 2007 | 08:27 PM
lost0138's Avatar
what options would we have to be able to put anti-lag on a usdm evo?
just wondering since im running a testpipe as it is. seems like it would be nice for the track
Old Dec 23, 2007 | 04:19 PM
rallykid's Avatar
Not THAT BAD, back in my Subbie days, I had a LINK ECM, no cats, and would run ALS all the time, turbo was totally fine. The down side is that you have to crank the throttle open 20-30% and leave it like that, and then idle is controlled with timing retard as well, so the car idles, well weird, but in a good way, lots of rally cars do it. Come to think about it, here is a link of my Subbie with ALS.
http://video.google.com/videoplay?do...arch&plindex=0
Tephra, and chance you can make something like tha and just caution ppl if you feel like, that Turbo life may suffer?
BTW: Sorry to hear about your accident, hope all is ok
Old Dec 23, 2007 | 07:25 PM
Jack_of_Trades's Avatar
ANTI-LAG has its up's and down's. Personally, if I build up any more boost off the line...my transfer case would be sprawled all over the track every time I visit. I build nearly 7-8psi with the basic rev limiter and traction is an issue already. If I had more power, I'd need to slip my clutch even more (I don't like shaving a layer of skin off of my clutch every time if I can minimize it). I can live with that much power off the line, and a much cooler turbo.
Old Dec 24, 2007 | 08:13 AM
rallykid's Avatar
ALS is not that much for launches, as it is for shifts, and engine braking into turns while keeping boost up.
soderdna
Oct 7, 2014 07:25 AM
jdtsunami
47
May 31, 2011 04:59 AM
cij911
Mar 26, 2009 08:17 PM
gaijin
Dec 31, 2005 08:33 PM
MuttedTsiAWD
11
Dec 17, 2001 09:28 AM
