Trouble. ECUflash wont Flash.
Old Dec 10, 2007 | 03:42 PM
s10v8's Avatar
This is what it is displaying. Any help is appreciated!
[15:39:10.121] Using interface OpenPort 1.3 Mitsubishi TX37FXvZ219bf4d58e9d33bcede04eaa91feb9b79dfba58b
[15:39:15.394] sending init sequence 1 (0001)
[15:39:16.438] got 0x05 response
[15:39:16.438] sending init sequence 2
[15:39:16.459] got 0x1B response
[15:39:16.459] sending init sequence 3
[15:39:16.866] entering bootloader
[15:39:16.874] sending kernel size (3588)
[15:39:16.906] sending kernel load address (0xFFFF8800)
[15:39:16.938] uploading kernel
[15:39:17.532] verifying kernel checksum response
[15:39:17.532] kernel valid
[15:39:17.740] kernel get version
[15:39:17.771] kernel version is : OpenECU Mitsubishi SH7052 Kernel V1.03
[15:39:17.771] reading kernel comm buffer size
[15:39:17.792] comm buffer size set to 512
[15:39:17.792] reading kernel flash buffer size
[15:39:17.803] flash buffer size set to 4096
[15:39:17.803] Flashing image to ECU memory...
[15:39:18.203] comparing ECU flash memory pages to image file
[15:39:18.203] seg start len ecu CRC32 img CRC32 same?
[15:39:18.234] FB01 00000000 00001000 15A33D92 15A33D92 YES
[15:39:18.265] FB02 00001000 00001000 FAE2FEE2 FAE2FEE2 YES
[15:39:18.296] FB03 00002000 00001000 03354BFC 0E1A6EBB NO
[15:39:18.327] FB04 00003000 00001000 3901D86F 3901D86F YES
[15:39:18.358] FB05 00004000 00001000 9D2A2AEB 9D2A2AEB YES
[15:39:18.390] FB06 00005000 00001000 FFEDA26A FFEDA26A YES
[15:39:18.422] FB07 00006000 00001000 B9D2C2FB B9D2C2FB YES
[15:39:18.454] FB08 00007000 00001000 2A8CF5E9 2A8CF5E9 YES
[15:39:18.607] FB09 00008000 00008000 8B6B957F 8B6B957F YES
[15:39:18.879] FB10 00010000 00010000 4BCDC4EA 4BCDC4EA YES
[15:39:19.143] FB11 00020000 00010000 3EB5B1CF 3EB5B1CF YES
[15:39:19.406] FB12 00030000 00010000 886D3C1F 886D3C1F YES
[15:39:19.406] kernel flash enable
[15:39:19.417] rkrv: can't read response payload
[15:39:19.418] interface close
[15:39:19.432] interface close
Old Dec 10, 2007 | 08:14 PM
s10v8's Avatar
Come on guys, I really need help on this. I searched and couldnt find an answer.
Please help.
Old Dec 11, 2007 | 06:17 AM
MalibuJack's Avatar
It could be PC related, and the transfer getting interrupted while its downloding, but try putting a battery booster on the car's battery. Once in awhile a failed download/flash can be attributed to low battery voltage. Its not very common on 03-05 cars, but it can happen.
if you can read sucessfully, but not write, then I would try to get someone with a cable and a good installation on a different computer to try it also.
You just want to rule out the possibility that the ECU's flash memory is not accepting new flashes (memory error or something. I wouldn't get too alarmed though because a truely bad ecu is a very very rare occurrance.
Old Dec 11, 2007 | 08:05 AM
s10v8's Avatar
Ok man I will try that and post back on here.
Thanks for the help.
Old Dec 11, 2007 | 11:16 AM
Ralph's Avatar
Sent you a PM s10v8 (the other site)
kassir
Oct 30, 2011 04:34 PM
MonacoGP
Apr 8, 2011 02:06 PM
napado
13
Mar 31, 2010 01:49 AM
SSS
Feb 18, 2010 05:08 AM
project_skyline
Apr 8, 2009 11:49 AM
