Which ROMID's have ICS
Old Dec 20, 2007 | 10:07 AM
codymac's Avatar
Originally Posted by logic
This is a good point that I should have mentioned when I originally posted; I'm pretty sure the code and tables for controlling the ICS are there, so assuming the necessary hardware is in place on the ECU itself, adding a switch to pins 91 and 44 ought to do the job, no?
Provided the code is there, and it's it's still being called by the main in the non-ICS cars. Otherwise, you'd have to re-enable (or add) the ICS code as well - unless tephra isn't depending on the OEM call(s) to it for executing what he's cooking up.
He'll have to explain depending on how he's going about the coding.
Old Dec 20, 2007 | 10:29 AM
SuPeRNeT's Avatar
96420007 I have ICS.
Old Dec 20, 2007 | 05:24 PM
tephra's Avatar
Yeah unfortunatley I dont think the ICS code is in 88590013/4/5 - I think I checked before...
Still that shouldn't matter too much as I have a simplified cut down version of button handler which I used ages and ages ago.
Still need to know if everyone is in favour of wiring in a switch OR finding a stock hardware way of doing it... Need some more suggestions ppl
Old Dec 20, 2007 | 08:46 PM
Tek3Evo's Avatar
I'm willing to wire a switch. just tell me what to buy and where to connect it to on the ecu!!
Old Dec 20, 2007 | 11:03 PM
Jack_of_Trades's Avatar
You need a momentary push button switch to mimic the stock ICS switch. If you end up changing the code so it can be set to be an on/off switch (one that lights up when on) configuartion in the ECU I think that would be cool (and helpful for the alky kit failsafe guys )
Old Dec 21, 2007 | 03:42 AM
tkklemann's Avatar
I am pretty positive it's all there, unless something is wierd in my maps that I have. I just full tuned a 88590015 last weekend, and I swear I remember all of the ICS still being there, and wondering why Mitsu never took it out. I will have to make sure all of the maps read correctly and what not now.
Old Dec 21, 2007 | 03:49 AM
Gpunkt's Avatar
88840016 & 88840017 no botton, only tables in ROM
IX 2006 EDM
Old Dec 21, 2007 | 07:43 AM
codymac's Avatar
OK - I just disassembled 88590015 and 94170008 and did a couple of quick/dirty checks based on the (different) addresses referenced in ECUFlash.
I'm not seeing where the map locations are referenced in the 88590015 code so it sure doesn't look like it's there, (unless the defs in ECUFlash are wrong).
Doesn't appear to be in the 88590015 code but I defer to tephra from lurking here long enough to know to take his word for it.
Putting data in a location doesn't mean it's ever referenced - sort of like buying a book, putting it on your shelf, and never reading it.
Oh... and I prefer the stock hardware way of doing it simply because it's a bit more elegant (and I'm lazy).
