Which ROMID's have ICS
Old Dec 16, 2007 | 05:28 PM
tephra's Avatar
Hey Guys,
Can ppl just post up whether they have intercooler spray button or not and their ROMID?
My next round of mods will probably utilise this button.
Cheers
D.
Old Dec 16, 2007 | 07:06 PM
Jorge T's Avatar
9417008 has ICS
Old Dec 16, 2007 | 08:01 PM
jba3's Avatar
Originally Posted by Jorge T
9417008 has ICS
Yes, same ECU ID I have. At first I got it confused with ISC.
Old Dec 16, 2007 | 11:48 PM
fixem2's Avatar
96940011 No ICS
Old Dec 17, 2007 | 06:43 AM
C6C6CH3vo's Avatar
Would this be something I can use? It can be hard to beat the patch that you wrote existing from last summer. You are a code Genius! Sorry, I had to say that, but you deserve the Nobel prize more than that lying fool Gore.
96420007
96420008
I think all USDM 03 and 04's have them right?
Old Dec 17, 2007 | 10:16 AM
logic's Avatar
Originally Posted by fixem2
96940011 No ICS
I can confirm this: 96940011, no ICS, 2005 MR.
Old Dec 17, 2007 | 11:34 AM
Oracle1's Avatar
UK one has. 88570008
Old Dec 17, 2007 | 03:32 PM
evo828's Avatar
EDM Evo 8 - 96530006 has it.
Old Dec 17, 2007 | 04:53 PM
mchuang's Avatar
94170014
Old Dec 17, 2007 | 04:56 PM
tephra's Avatar
hrmm ok - I'm going to release V4 of my mods today sometime, however it will only be for ICS equipped evo's
Old Dec 17, 2007 | 05:43 PM
jba3's Avatar
I believe this is correct. The 03/04 had the ICS and the 05+ did not, but they may have left it in the ECU so we should double-check.
Old Dec 18, 2007 | 11:46 PM
codymac's Avatar
2006 USDM IX MR - no spray button
88590014
Old Dec 19, 2007 | 04:49 AM
tkklemann's Avatar
96940011 No ICS
Correct. We do have all the maps in the ROM...
But, my question is, couldn't we still use this assuming that since we (the 05 0011 ROM guys) do not have the ICS, the pins might still be on the ECU, just unused? If the pins are there, but unused, we could simply wire in a switch for the map switching.
Possible?
Old Dec 19, 2007 | 08:34 AM
logic's Avatar
This is a good point that I should have mentioned when I originally posted; I'm pretty sure the code and tables for controlling the ICS are there, so assuming the necessary hardware is in place on the ECU itself, adding a switch to pins 91 and 44 ought to do the job, no?
Old Dec 19, 2007 | 09:28 AM
ko_racer's Avatar
UK Evo VIII FQ300 93660005 - Does have ICS
