from 88590014 to 88590015?
Old Dec 20, 2007 | 02:57 PM
codymac's Avatar
Question from 88590014 to 88590015?
I spent the better part of the afternoon reading and updating the xml for 88590014 to set up 2-byte everything for some baseline work. Over to Evoscan only to see that there's nothing for 88590014 there... great.
In all the reading/searching, it certainly appears that 88590015 is the most common, and where the majority of IX work is being focused.
I'm moments away from throwing in the towel and flashing to 88590015.
Not really enthused about the prospect of disassembling both and spending hours doing a stare & compare though.
Who here has done it?
(Nov 2005 build 2006 USDM IX MR)
Old Dec 20, 2007 | 04:11 PM
nj1266's Avatar
I tuned a friend's Evo 9 that had the 0014. I simply put his immobilizer code into a 0015 and flashed it into the ECU. It worked with no problems at all.
Old Dec 20, 2007 | 06:26 PM
RazorLab's Avatar
I've switch about seven evos from 14 to 15 with no problems.
Old Dec 20, 2007 | 07:10 PM
nj1266's Avatar
I did it only once and I was freaked out that it was not going to work
Old Dec 20, 2007 | 07:57 PM
codymac's Avatar
Awesome - thanks, guys.
I'll start out with 15 then!
Old Dec 21, 2007 | 06:05 PM
daisaw1219's Avatar
i did 13's to 15s
Old Dec 22, 2007 | 03:26 PM
codymac's Avatar
Numb fingers from the biting cold wind while hooking up the charger on the drive but she's got 15 loaded now.
Thanks again for confirming the "should work" I'd read before I pulled the trigger!
Old Dec 23, 2007 | 01:21 PM
BiFfMaN's Avatar
yah i had a messed up 13..could not change injector size...so simply changed over to 15.
Old Dec 23, 2007 | 08:29 PM
JohnBradley's Avatar
Its not messed up, you have to add a different definition to make it work but the 13 & 14 can still be used to scale injectors.
Old Dec 23, 2007 | 10:31 PM
BiFfMaN's Avatar
yah i saw someone post that after i flashed it 15...back then could not find the fix.
Old Dec 23, 2007 | 10:40 PM
https://www.evolutionm.net/forums/sh...d.php?t=264937
Old Dec 24, 2007 | 04:52 PM
BiFfMaN's Avatar
Thanks...and yah that was posted like a few days after i just swapped..lol.
But gratz
recompile
Sep 28, 2018 03:19 PM
jcsbanks
Jun 9, 2011 11:45 AM
xmaciek82x
Aug 25, 2009 11:03 PM
Mr Evolution
Apr 24, 2009 05:26 PM
andrewzaragoza
May 16, 2008 06:45 AM
