load rescaling and knock sensor filter maps
I just noticed that when you rescale your load range on the x-axis for the ignition map, it also rescales the load axis for the knock sensor filters. Unless you were to go into each of those filters and keep the values under the correct columns (and extrapolate out for the higher than stock load columns), you would in effect be reducing the knock sensitivity at higher loads, wouldn't you?
I'm not a hardcore EcuFlash guy, so I may have missed this topic being addressed, but I did a search and couldn't find anything.
Thanks!
Thanks!
Actually, wait a sec. Do the stock knock filter maps already go to 320 without rescaling? My load maps were rescaled out to 320, but now that I look at the patched Tephra map that I was working from to install the latest patch (i.e., not rescaled yet), I see that the filters in that base map already go to 320 while the load columns in the timing and fuel maps only go to 260 (as you'd expect for stock).
My ROM is 96420008 FWIW.
