94170008 def error and fix
Old Jan 16, 2008 | 05:35 AM
Mad_SB's Avatar
Guys,
While transfering my maps over to tephra's 4.2 uber rom, I noticed that the defs have an error in at least the following ecuflash versions (1.29 & 1.34).
The start address for knock sensor filter map 1 is not correct in the 94170008.xml as a result the table is scewed by one column.
Not a big deal as most folks will never touch the filters, but if you want to correct the def you can do the following:
Replace
<table name="Knock Sensor Filter Map 1" address="4850">
with
<table name="Knock Sensor Filter Map 1" address="485b">
in your 94170008.xml file
Old Jan 16, 2008 | 09:43 AM
honki24's Avatar
hmmm... actually I do mess with that table.... That might be very helpful to me.
Old Jan 16, 2008 | 02:37 PM
Slo_crx1's Avatar
That's old news, I found the same thing a few months ago and someone mentioned they already knew about it. Maybe it would be good to start a thread to try and have stickied with all the MUT address fixes and add-ons, such as the one you mentioned here and others like 2-byte load/maf/rpm etc.
Old Jan 16, 2008 | 04:07 PM
tephra's Avatar
Yeah perhaps an "EcuFlash XML change thread" - that or someone can get onto Corby's team to integrate this fixes into the next release of EcuFlash
mrfred
Dec 15, 2022 11:13 AM
mrfred
Feb 26, 2022 06:16 PM
Benja
Jul 3, 2019 12:42 PM
PPM
Apr 2, 2015 09:35 AM
Tuner@Swift
Aug 22, 2008 01:47 PM
