ECU code & Boost & WTF
Old Feb 4, 2008 | 06:51 PM
mrfred's Avatar
I don't think Mitsu made a mistake. They want to use the same code for many vehicles, and rather than create a new piece of code that does not any refs to Table #2, they just make it so that Table #2 is never called, and so they don't worry about what is actually in the table. tephra, if you look below the active WGDC routine, you'll see there is another WGDC routine that is not used. All kinds of redundant/unused stuff in the ROM.
Table "#3" is a real table, and it can be called if someone sets the boost limiting vehicle speed to an attainable value. Suggest not deleting that table from the xml. Using the space in ROM where table "#2" is located could be good. Where are you storing your alt maps for fuel and ign?
Old Feb 4, 2008 | 08:12 PM
tephra's Avatar
hey mate,
#2 could definitely be used, just because we haven't seen it be used doesn't mean it wont.
I would actually consider #2 having a higher chance of being used than #3.
#3 only gets used if the ROM (and I haven't seen one yet) has "boost limiting speed" set low, ie not 0xFFFF.
yeah I saw the redundant WGDC routine... lots of unused code in the ECU
edit - my patch overwrites the code that selects map #3... I can't see anyone using the "boost limiting speed"
Old Feb 4, 2008 | 10:41 PM
tephra's Avatar
Just further to this, the variable that controls whether we choose map #1 or map #2 is the SAME variable/bit that controls whether we should use openloopload #1 or #2.
I am trying to trace it now, but its referenced about 300+ times so finding the right bit of code is difficult.. then you have to trace that code backwards
edit - interestingly enough this variable is set in the Read_Ports subroutine basically:
mov.l @(h'29C,pc), r10 ; [0000BC8C] = unk_FFDF
and r10, r13
mov #h'20, r10 ; ' '
or r10, r13
then later on it pushes r13 back into the variable in question.
Now for those that can't read assembly the above does nothing... LOL!!
However because of the complexness of the code it could be changed someplace else... either way I still stand by my original statement
Old Feb 4, 2008 | 10:57 PM
codgi's Avatar
Originally Posted by tephra
hey mate,
You might have to do futher investigation on #2 then. Code is pretty stupid...either it can do something or it can't. Right now it sounds like you aren't sure about all the conditions that determine the branch into #2 .
Old Feb 4, 2008 | 11:03 PM
tephra's Avatar
well my logs indicate and the code indicates that it *should* never branch into #2, however I wouldn't consider this 100%.
IF IT DID branch into #2 then the data read back would be rubbish.
Old Feb 4, 2008 | 11:12 PM
mrfred's Avatar
If the ECU ever choose table #2, the boost would go haywire because there is no viable data in the location location where table #2 is supposed to reside. Since it never goes haywire, its easy enough to know that the ECU never goes into table #2. Its more of an experimental result, but the answer is definite.
Old Feb 4, 2008 | 11:13 PM
codgi's Avatar
Fair enough . Sorry for giving you such a hard time but I always hear "should never" at work which usually lasts all of 3 minutes before it becomes "how the <insert favourite curse word here> did you get it to go down that code path?"
This is pretty common in release code though honestly. Code gets put in temporarily. Someone forgets to take it out, and by the time someone else finds it back its already to late to pull it without destabilizing the whole product. Cheaper to push it out the door as is.
Old Feb 5, 2008 | 03:38 PM
burgers22's Avatar
Well I don't know how relevant the code in my 7 is to this, but I deffinatly refferance all the tables correctly. Though I am assuming we are looking at code doing a similar job.
MB
Old Feb 5, 2008 | 11:28 PM
al\lupo's Avatar
Also in EDM IX 88840016 and 17 #2 seems "incorrect".
Old Feb 6, 2008 | 06:29 AM
burgers22's Avatar
Check post 19 in this thread, the plot thickens https://www.evolutionm.net/forums/sh...88#post5247888
MB
Old Feb 6, 2008 | 11:44 PM
codgi's Avatar
True but as a real tester I would say that tells me that in that particular test case the code is never hit, but it doesn't tell me whether that test case ever had a chance of being able to get the code to execute in the first place .
Unless the code is fully traced i wouldn't say the answer is definite. Thats a good way to find myself on the bread line
If it was me and I really wanted to find out if that code could ever be called I would:
1) look at the function that ends up pointing to #2.
2) Map all input parameters (if any) and look at all their bounds as well as any global variables used
3) Determine how those input parameters (if any) vary the running of that particular function
4) Map all other functions/code that call into this code as well as input parameters sent to the function
5) Map the functions that call those functions and so on and so forth
Doing the 5 steps above very thoroughly will with 100% certainty answer the question as to whether or not it can ever truly be called.
Old Feb 6, 2008 | 11:56 PM
tephra's Avatar
the function itself is very simple, however the control branch uses a VERY common variable, referenced in over 200 places... so going back and saying with 100% certaincy is very difficult.
its just easier to fix up the pointer like what I did in V5
Old Feb 7, 2008 | 11:01 PM
codgi's Avatar
Welcome to my world .
mnr12
For Sale - Cars For Sale
40
Jul 28, 2009 08:38 PM
BocaShula
For Sale - Part Outs
36
Oct 19, 2008 06:00 PM
Gsxtremedsm
14
Jun 19, 2008 06:08 PM
haze1995
Dec 12, 2007 12:44 AM
Jeff_Jeske
Jun 26, 2007 08:43 PM
