Evoscan help!
Old Feb 7, 2008 | 03:28 AM
rolly1818's Avatar
Registered User
Question Evoscan help!
I have a JDM 2006 Evo IX GSR.
I will be using Evoscan for the first time later on today to log the following:
a. Throttle Position
b. Engine RPM
d. Knock Sum
f. Injector Duty Cycle
g. AFR Map
h. Coolant Temp
i. Timing Advance
I just have two quick questions about using Evoscan:
1. When do I start Evoscan and end it? Do I start it exactly before I go WOT (at ~2000 rpm in 3rd?) and end it IMMEDIATELY at redline (7500 rpm?) before I switch gears?
2. Does Evoscan automatically give me my Torque/Horsepower or do I need to log something other than those listed above? And how do I view the HP/Torque readout?
Thanks guys!
Old Feb 7, 2008 | 04:02 AM
electricevo's Avatar
You will have to hit review log and then select power to see your HP/TQ. you're logging TPS, so you can start the log and wait a few seconds to make sure the data is streaming, then go from 2500 to redline. Then stop the log.
whne you review, when you see 100% TPS, thats when you started. (or you can filter the log by TPS using only WOT)
Old Feb 7, 2008 | 05:56 AM
rolly1818's Avatar
Registered User
Thanks...so i should be able to get HP and TQ. nice!!! juust waiting for some clear road!
Old Feb 7, 2008 | 05:58 AM
MadMsheen's Avatar
I begin Evoscan right after I start my car, drive it to work (10 miles) then turn it off when I get there. I get some runs in between.
When reviewing WOT runs, I just select the TPS column, and find the 100 value. I highlight every WOT run I make and go from there. There are things being logged while driving that I like to see that are not in the WOT runs. Which has assisted in helping me tune my car better for daily driving as well.
Old Feb 7, 2008 | 06:00 AM
rolly1818's Avatar
Registered User
anyonce have a smaple log to share with me? just so i can start to get aquainted with it? nothing too complex though.
Also which is a good portable Wideband?
Old Feb 7, 2008 | 06:32 AM
letMeIn's Avatar
post your experiences when you get to use it... Looking to start using EcuFlash.
Old Feb 7, 2008 | 06:52 AM
TouringBubble's Avatar
If you use the EvoScan log viewer, you can easily select your WOT pulls from the "Power" tab. there is a pull down menu in the left column (I believe titled Power Runs) that should list all of your WOT pulls. I believe it's based on RPM over time ... I think speed needs to be logged as well in order to view HP/TQ in EvoScan since it calculates the gear from speed vs RPM.
If you want your EvoScan logs to be useful for tuning, log these values ...
TPS
RPM
Load (2-byte or Calculated ... calculated load requires battery, AFR Map and one other value as well)
Timing Advance
WBO2 (If you have it ... O2 sensor #1 if you don't)
Knock Sum
Octane
IPW (requied for IDC%)
With a few additions to the XML you can also log 2-byte Airflow, compressor lb/min and even HP and TQ right in to your log.
Old Feb 7, 2008 | 07:39 AM
rolly1818's Avatar
Registered User
thanks touring..once again u helped!
letmein, i will let u know if u want to chat about ecuflash dont be afraid to ask some question or PM me. i think i know the basics of ECuflash so i can help.
Evoscan i am just learning.
Old Feb 7, 2008 | 05:18 PM
Bexa20's Avatar
MadM when you say you log while you cruise, what in particular are you looking for at that point?
Old Feb 7, 2008 | 06:55 PM
rolly1818's Avatar
Registered User
Great Questions Bexa20, would love to hear the answer to this one!
i use my Evo as a daily driver myself....so any help here is greatly appreciated!
Also does anyone elses Evo idle roughly? mine is bone stock
Old Feb 8, 2008 | 02:20 AM
rolly1818's Avatar
Registered User
anyone?
Old Feb 8, 2008 | 09:46 AM
rolly1818's Avatar
Registered User
