Disable clutch down to start car functionality
Old Feb 11, 2008 | 10:03 PM
sharkm87's Avatar
Hey, I recently installed Tephra's NLTS ..which works great btw
however i have a remote start so initially i had the clutch switch disconnected physically...anyone know of a way in the ECU to disable that?
where even though the cable is connected, the ECU bypasses that and will start start the car without pressing the clutch??
thanks.!
Old Feb 11, 2008 | 10:05 PM
tephra's Avatar
so my thought is that this "car wont start without clutch down" thing could be a "bit flag" from the 0xFAA flags.
so do some research on aktivematrix.com - there is a big thread about the bit flags. someone might have already discovered it.
Old Feb 11, 2008 | 10:06 PM
sharkm87's Avatar
thanks..looking into that as we speak
Old Feb 12, 2008 | 06:10 AM
nothere's Avatar
the clutch no start switch and the nlts clutch switch are two different animals.
you can have both without doing anything special.
Old Feb 12, 2008 | 06:51 AM
l2r99gst's Avatar
Agree. I have had my safety switch disabled from day 1. I was one of the first to test Tephra's NLTS patch and it worked and has been working fine ever since without my safety switch connected.
By safety switch, I mean the clutch switch that, when connected, disables you from starting the car unless the clutch pedal is depressed.
Eric
Old Feb 12, 2008 | 06:57 AM
bigric09's Avatar
+ 2...
mine as well
Old Feb 12, 2008 | 07:21 AM
kkarim's Avatar
if i'm not mistaken, there are two clutch switches, the bottom switch that prevents the car from starting, and the top switch that is used for NLTS.
Old Feb 12, 2008 | 08:53 AM
l2r99gst's Avatar
Actually, I think there are three, but don't quote me on that.
Old Feb 12, 2008 | 12:36 PM
sharkm87's Avatar
woah wait....i thought there was just that one switch with the long white stick on it....and just one connector behind it..am i wrong?
Old Feb 12, 2008 | 12:45 PM
sharkm87's Avatar
guys, you are absolutely right...i disc it and went out..little skeptical..but yes it did work...
i feel dumb
Old Feb 13, 2008 | 05:33 AM
rolly1818's Avatar
Registered User
Ntls?
Old Feb 13, 2008 | 05:40 AM
sharkm87's Avatar
NLTS...tephras mod
Old Mar 5, 2008 | 01:09 AM
vboy425's Avatar
why go through he trouble flashing. just disconnect the sensor behind the clutch.
Old Mar 5, 2008 | 03:30 AM
tkklemann's Avatar
The only thing is if you have a 2-step launch in your car, it needs the bottom clutch switch to trigger it operational.
Old Mar 5, 2008 | 03:55 AM
sharkm87's Avatar
nope, not true.....i have the bottom disconnected, remote start and 2-step and nlts all work just fine
neloner
Feb 7, 2015 08:18 PM
EVOMIZ
Nov 27, 2011 05:33 PM
bnr34rb26dett
Oct 24, 2011 07:07 PM
rdtech
Jul 30, 2009 08:10 PM
