How to install/use a wideband O2 sensor?
Old Feb 15, 2008 | 04:37 AM
nplatenkamp's Avatar
Hi gurus, i searched but did not find any usefull installation guide of a wideband O2 sensor.
1. can i just replace my original lambda sensor ?
2. can use the output directly by my stock ECU (and Evoscan)?
3. do i need special interface ?
Thanks for any help!
Old Feb 15, 2008 | 05:14 AM
FuelsResearch's Avatar
I am far from a guru but :
1. You weld a bung into the downpipe before the cat
2. No outputting from ecu, evoscan can link to most popular WB02 models. Some include specific logging software i.e. Innovate's Logworks
3. By interface, I assume you mean logging software, see above
There are multitudes of setups people employ around here. Search terms like LC-1, zietronix and a bunch of useful threads will show up.
The Innovate LC-1 is very popular. Innovates website has a PDF manual for the LC-1 you could download. It is very informative.
Old Feb 15, 2008 | 05:41 AM
sharkm87's Avatar
as far as number 1 goes, it has to be between 10 and 2pm.....so no condensation gets on the sensor
Old Feb 15, 2008 | 05:54 AM
Thanks, i know this but must i keep the original O2 sensor? (after turbo)
Or where does the output signal from the wideband goto ?
Old Feb 15, 2008 | 05:59 AM
sharkm87's Avatar
yea, you keep the stock o2 sensors....the out put for wideband would normally go to a gage and your laptop...but it all comes in a kit....have you decided on which one you will be getting??? theres actually a write up around here on testing done on a bunch of kits...lc-1 and the uego..zietronics
Old Feb 15, 2008 | 07:26 AM
[QUOTE=FuelsResearch;5287191]I am far from a guru but :
3. By interface, I assume you mean logging software, see above[QUOTE]
Thanks, but can I log the AFR signal with Evoscan 2.0 ? Or must i log it seperately and then combine them somehow ?
Old Feb 15, 2008 | 07:30 AM
Evoscan can log most of the popular widebands. Innovate also has its own logging software that can be used. Other brands probably do as well.
Old Feb 15, 2008 | 07:31 AM
sorry, i found it already in Evoscan you can select it. Great.
Thanks again.
WRECKLESS96
Sep 5, 2009 09:50 PM
shunderwunder
Nov 30, 2007 04:11 PM
boony
21
Nov 24, 2006 01:54 PM
spyderx
14
Nov 24, 2006 08:08 AM
BRKENG
Aug 8, 2004 05:32 PM
