whats so special about 96940011?
Old Feb 19, 2008 | 06:01 PM
Asmodeus6's Avatar
YAY, my ROM! Tephra... don't be shy... TEAR IT APART!
Old Feb 19, 2008 | 06:14 PM
tephra's Avatar
Well ICS code isn't in this ROM... so that sux
Looking for chunks of space that I can use... Trouble is this approach will probably net more errors and snafu's
oh well, I am really interested to find out what is in this rom that isn't in other 8's. ADC can't be it, must be something else
Old Feb 19, 2008 | 06:16 PM
alan678's Avatar
Thats the ROM in my car....05 Evo...
Old Feb 19, 2008 | 06:35 PM
tephra's Avatar
does 96940011 have a MAP sensor?
Old Feb 19, 2008 | 06:52 PM
alan678's Avatar
Nope.....just the crappy 1bar.....
Old Feb 19, 2008 | 06:53 PM
RazorLab's Avatar
All the US model Evo's have the 1bar map sensor.
The Evo X has the 3bar.
Old Feb 19, 2008 | 07:01 PM
tephra's Avatar
Hrmm ok...
I'm still on the hunt for redundant code.. :P
Old Feb 19, 2008 | 07:34 PM
tephra's Avatar
can someone email me their stock 96940011 rom?
I want to dbl check the one im working on is stock
tephra (<at>) gmail etc etc
Old Feb 19, 2008 | 07:54 PM
crisdawg's Avatar
rom sent.
Old Feb 19, 2008 | 08:00 PM
tephra's Avatar
thanks.. damn its the same...
well this is getting worse and worse, the rom space that i was currently planning on using is actually being used in a block copy routine, in-efficient but thats life..
so now i have even less space to play with
Old Feb 19, 2008 | 10:35 PM
tephra's Avatar
hrmm this is looking to be almost an impossible task - i really dont want to change the stock ecu bits too much, mainly because we don't have enough information about whats going on, and if we do something wrong it could be very bad
the problem is there isn't enough contiguous space to store the code and altmaps, i have found a redundant routine that almost gives me enough space if I kill it, but then I still need to find space for the maps...
really annoying, 96940011 has about 2k of freespace, and only about 500bytes is contigous, whereas 94170015 has like 10k of freespace and its all together
/waaaaaa
Old Feb 19, 2008 | 10:40 PM
RazorLab's Avatar
So what's the deal with 94170015?
Is it a 05 rom? USDM?
I have a spare 05 ECU here I can test stuff if needed.
Old Feb 19, 2008 | 10:43 PM
JohnBradley's Avatar
/waaaaaa
Dave, I have one that was originally labelled as a 96940015. I didnt feel like writing an xml for it (got it from Lucas, its alledgedly the latest P0300 fix for the 05). Anyway I renamed it as 96940011 and it lined up exactly. I can send it if you want to take a look?
Aaron
Old Feb 20, 2008 | 03:21 AM
tkklemann's Avatar
At one time, I thought someone mentioned that the different ACD modes would cause timing changes.
I probably don't understand code and all the stuff well enough, but if in fact the ACD changes timing, wouldn't there be maps and a bunch of stuff related to that taking up space? Maybe that's the reason?
Old Feb 20, 2008 | 02:46 PM
tephra's Avatar
not that I saw, the space was mainly taken up by additional code, can't tell whta it does thou
