Help with CEL
Old Feb 19, 2008 | 09:11 AM
wek's Avatar
wek
Help with CEL
Hi Guys and Gals,
I just bought a 2006 JDM EVO 9 MR, and I am thinking of getting upgraded downpipe and test pipe that will replace the stock Catalytic Converter. What worried me is the CEL. I was wondering if there is a way to eliminate the CEL to go off that is related to the CAT DELETE ONLY, apart from using the mechanical CEL fix. I am wondering if Stock ECU Reflash could make the CEL gone (Or disable the secondary O2 sensor)?
On a side note, i was so happy that I could fine this forum as all the other evoution forums are not as good as this. Thats why I enter this forum and look for help regarding this issue (hopefully JDM EVO and USDM EVO will react the same to this circumstances). Thank you in advance people. Cheers.
Old Feb 19, 2008 | 10:02 AM
DrivinMissDaisy's Avatar
If you search there is a delete for the rear cat, because I am using it.
Old Feb 19, 2008 | 10:41 AM
chu's Avatar
chu
If I remember correctly, there's a patch out there to turn off the CEL. But remember, disabling will only turn it off in the dash. The ecu will still notice it, and you will fail emissions
Old Feb 19, 2008 | 06:37 PM
wek's Avatar
wek
Thanks for all the inputs. If disabling the Secondary O2 sensor is possible, then I do not think that the ECU will notice it, therefore the car will run normal (as in not in protection mode or something) as if there was never a secondary O2 sensor initially. By the way, there is no emission test in my country.
All other inputs will be greatly appreciated.
I would much rather disabling the secondary O2 sensor through ECU flash if possible rather than having the mechanical CEL fix.
Thank you
Old Feb 20, 2008 | 05:04 AM
2nd o2 sensor does nothing for performance. The CEL it causes will not put the car in limp mode.
Old Feb 20, 2008 | 05:44 AM
dino21's Avatar
okk so when im getting just cat back ,do i still make this or it wont affect the 02 secondary sensor and so the ECU. THANKS.I have EDM EVO
Old Feb 20, 2008 | 06:32 AM
Mellon Racing's Avatar
why not simply install the spark plug anti-fouler for the rear 02 sensor...works like a champ for me.
Old Feb 20, 2008 | 02:59 PM
tephra's Avatar
romid?
Old Feb 21, 2008 | 04:07 PM
Asmodeus6's Avatar
I still get the light with this... I have to clear it all the time its SO annoying.
I don't know why it doesn't work for me.
Must be your magic beans Chris.
Old Feb 21, 2008 | 04:14 PM
Murf's Avatar
did you use one fouler or two?
Old Feb 21, 2008 | 04:34 PM
Old Feb 21, 2008 | 04:45 PM
Asmodeus6's Avatar
One... I think. I'll have to look again. I didn't do it. It came done on the car when I picked it up. But it absolutely doesn't work for s***.
Its so randomly comes on too. Sometimes I get a couple hundred miles, sometimes I get like right down the street from clearing it and DING... SES. Now that puts me in a midget kicking fit of rage...
Old Feb 21, 2008 | 04:51 PM
bnice01's Avatar
x2
Old Feb 21, 2008 | 04:54 PM
tephra's Avatar
Dustin - what ROMID?
Old Feb 21, 2008 | 04:57 PM
Asmodeus6's Avatar
96940011 - the USDM 05 Rom.
The one I begged you to rip apart in your other thread.
Now you see why Tephra. I still rock your patched rom because the CEL on knock is awesome. And even tho it still works with the CEL on... its nicer when its off.
