Help with CEL
Old Feb 21, 2008 | 10:02 PM
JohnBradley's Avatar
Add this to your Evo9base.xml
<table name="02 sensor (periphery 0)" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
If the value is not 0x56D8 then enter that value and then reflash...done.
If it is already 56D8, then you should be good to go. I used 2 anti foulers when that method first "came out", drilling the one all the way through and then threading it into the second. It worked about 300 miles at a time. This works 100% of the time no worries. I am also my own state emissions inspector where I live so I always pass.
Old Feb 27, 2008 | 07:01 AM
xsolowx's Avatar
The antifouler physically will not fit on mine...even with the shorter ones it doesnt clear the floor of the car (turbo xs catback). i tried using the bung in the test pipe, but it hangs too low..if i flip it, it wont clear the drive shaft
barrman
Oct 23, 2012 05:48 PM
bsvaton
Oct 13, 2010 09:51 PM
huevosrancheros
Mar 27, 2008 03:20 AM
ghoonk
Jan 1, 2007 10:00 AM
Blue Evo 8
Jan 9, 2006 12:09 AM
