Mitsu 3bar MAP sensor
Old Dec 8, 2008 | 07:24 PM
35rEvo's Avatar
Originally Posted by MIVEC 4G63
this replaces the maf? i'm confused...
Indeed you are. This is a MAP sensor. It is used to log boost.
Old Dec 8, 2008 | 07:51 PM
tobz's Avatar
Correcto! and works like as champ.
Old Dec 9, 2008 | 09:41 AM
MIVEC 4G63's Avatar
Wow I'm confused but you're not entirely correct either, it's not used to log boost, it could be if you rewrite your map and use a jdm MAF. Older hondas like b16, b18 are non turbo and use a MAP only. it's a MAP sensor, "Manifold Absolute Pressure sensor". It's there to calculate air density and determine the engine's air mass flow rate(MAF). In my Rx7 I used a Haltech E6x which replaced the MAF with a 4bar MAP. So going back to square one do you need a MAF when running a 3bar MAP and rewriting the ecu map?
Old Dec 9, 2008 | 09:50 AM
honki24's Avatar
yes, you still need your MAS. The MAP is used solely for logging.
Old Dec 9, 2008 | 10:46 AM
black_evo's Avatar
At least you know how to search. http://en.wikipedia.org/wiki/MAP_sensor
35revo is correct. The 3 bar MAP sensor is used to log boost....
Old Dec 9, 2008 | 10:47 AM
mrfred's Avatar
Currently the JDM 3 bar MAP sensor is used to:
1) Log boost (the stock 1 bar MAP sensor is good only to 2 psi of boost)
2) Control boost
It can also be used as part of a MAF to MAP conversion, but there there are only a few people out there with custom patches for the conversion. There is no publically available patch yet.
Old Dec 9, 2008 | 10:50 AM
fryedchikin's Avatar
The 3 Bar MAP sensor does not replace the MAS and is not solely for logging.
The 3 Bar MAP sensor replaces the standard 1 Bar sensor and when installed correctly will perform all the same functions as the 1 Bar PLUS give you the added ability to log boost.
Old Dec 9, 2008 | 05:59 PM
MIVEC 4G63's Avatar
oh ok thanks a lot guys
Old Dec 14, 2008 | 07:31 AM
MIVEC 4G63's Avatar
So does anyone know how not to run MAF?
Old Dec 14, 2008 | 08:08 AM
jmelocik's Avatar
As stated earlier there are a few guys doing it but haven't worked all the bugs out yet so nothing has been released for general consumption yet. LOL On a sad note I was informed that one of the guys who did it first blew his motor on his first attempt to tune it.
Josh
Old Dec 16, 2008 | 07:24 PM
MIVEC 4G63's Avatar
Josh
yeah not good.
Old Dec 18, 2008 | 03:07 PM
MIVEC 4G63's Avatar
do you feel good about yourself?
retard
Old Dec 18, 2008 | 04:20 PM
C6C6CH3vo's Avatar
retard
No name calling please.
MAP is a standard of measuring load on non-MAF systems but the sensor can also read PSIa as PSI in order to log pressure on the charge. I'm not sure the range of the sensor (I use a 10bar) or if it is zeroed to 1atm and reads in/Hg as -PSI as mine does, but the sole purpose of using one is for tuning from logged boost, in most cases on an MAF system, that's it.
Old Oct 2, 2010 | 08:53 AM
mchristian's Avatar
Anyone know if MrFred is still selling the 3 bar MAP sensors? I've pm'd and emailed him and have not gotten a response...I read he had them cheaper than mitsubishiparts.net.
This sensor was going for $125 "shipped" but they kept increasing the price.
Now it's over $50 more??? Ridiculous...
$152.02 + $18.24 for shipping...on something that's small & weights a few onces!
Old Jan 25, 2017 | 12:58 PM
blitzkreig's Avatar
is this the same map sensor used on the jdm evo ix?
Evo_AK
29
Jan 12, 2018 05:42 AM
Eunsangie
Aug 17, 2017 09:21 PM
Boostin_AWD
May 18, 2016 01:19 PM
SkyNight
May 15, 2016 04:03 AM
RussellM
Mar 20, 2016 09:29 AM
