Immobilizer code - other reasons
Old Feb 21, 2008 | 08:07 PM
gt420hp's Avatar
I have a buddy who is doing his own tuning, and his IX runs pretty well. I wanted to try his map. I loaded the hex file on my laptop, went to the immobilizer code field and changed it to match my ECU file.
When I load his map, with my correct immobilizer code, the car won't start? Luckily I saved my original map, reloaded my map, and the car starts fine.
Is there someplace else preventing the car from starting? I have the correct immobilizer code, and the init code. I don't know any place else that needs to be correct? Both cars are 2006 IX's.
Old Feb 21, 2008 | 08:17 PM
evo8426's Avatar
make sure you enter the the number as 0x and then the number that your immobilzer is, such as 0x8352
Old Feb 21, 2008 | 08:49 PM
gt420hp's Avatar
Yep, did that, typed in 0x3A01, and it shows up in the box as 3A01. Same as my original ECU flash. Init codes are 0001
Old Feb 21, 2008 | 08:52 PM
evo8426's Avatar
dont enter letters into the box make sure they numbers. in mine its only numbers that show up. could you post your rom and immobilizer code?
Old Feb 22, 2008 | 12:27 AM
RazorLab's Avatar
Some immobilizers have letters as well
OP: Does your friend have a JDM map sensor?
Old Feb 22, 2008 | 03:31 AM
gt420hp's Avatar
I have letters, my 2004 EVO had letters also. His rom has a 9001. We don't have a sensor.
Old Feb 22, 2008 | 03:34 AM
Jack_of_Trades's Avatar
I'd go through the tables and see if anything isn't matching up. Injector scaling the same?
Old Feb 22, 2008 | 03:55 AM
tkklemann's Avatar
Why don't you just copy all of his maps over to your ROM, instead of using his ROM in your car.
A little more time consuming, but almost guaranteed to work.
Old Feb 22, 2008 | 11:56 AM
gt420hp's Avatar
I haven't tried copying maps that way, is it as simple as copy and paste? or do you have to copy and paste each individual cell in each table...now that would take forever...
Old Feb 22, 2008 | 02:40 PM
mplspilot's Avatar
You can copy paste the whole field or as many/few cells as you'd like.
Old Feb 22, 2008 | 03:10 PM
Malmoe_Sweden's Avatar
Immobilizer problems
I agree with mplspilot that you should be able to copy and paste as much as u like without having problems with immobilzer....BUT
Read my tread https://www.evolutionm.net/forums/sh...d.php?t=326070
What U are describing happend to me as well.
I found out that my ign tables didn´t have any values..... Everything looked fine in ecuflash but something had happend.....it shouldn´t but it did.
I had to copy and paste it all over again. Just to make shure that u have usable values u should highlight them and increase all values by 1 and go back again.
It worked fine for me......
// Lars
Old Feb 22, 2008 | 03:12 PM
Yeah, just click and drag to highlight the area you want to copy. Then you just right-click it and copy the highlighted area (or hit CTRL+C). Then you highlight the EXACT same area in the other rom and just right-click the area and select 'paste' (or hit CTRL+V).
Old Feb 22, 2008 | 06:32 PM
gt420hp's Avatar
thanks, I will try this over the weekend and see what happens.
Old Feb 22, 2008 | 06:49 PM
tephra's Avatar
what codes did u get?
SiC
Jan 19, 2016 08:03 AM
EVOMIZ
Nov 27, 2011 05:33 PM
rdtech
Jul 30, 2009 08:10 PM
Oettinger
Mar 9, 2008 06:29 AM
evo4mad
Dec 1, 2006 03:08 PM
