beginner tuner:
Old Feb 25, 2008 | 07:39 AM
Mellon Racing's Avatar
Originally Posted by 20Grockit
haha. well how much do i have to pay you for just the latencies on the injectors.
true you can find some values on the forum but I can't count how many customers tried them and ended up coming to me anyway because the freebies didn't do the job.
good luck and pm me if you need help, maybe we can work out something on the pricing
Old Feb 25, 2008 | 07:43 AM
Billy@EnglishRacing's Avatar
just remember you get what you pay for
Old Feb 26, 2008 | 03:38 AM
20Grockit's Avatar
yea exactly which means im probably gonna go to chris
Old Feb 26, 2008 | 02:53 PM
20Grockit's Avatar
hey chris i got some latencies. let me know what you think and if they sound about right to you.
7.00 2.186
9.40 1.369
11.7 0.895
14.0 0.610
16.4 0.419
18.6 0.290
Old Feb 26, 2008 | 03:01 PM
RazorLab's Avatar
you dont know what they would be for precision 780cc injectors do you??
A good start:
Scaling: 696
Latencies:
3.504
1.872
1.248
0.96
0.744
0.552
0.432
Fine tune for your evo from there
Old Feb 26, 2008 | 03:03 PM
srt2evo's Avatar
good thread. subscribed.
Old Feb 27, 2008 | 03:35 AM
20Grockit's Avatar
thanks for the help man.
Old Feb 27, 2008 | 04:58 AM
Jack_of_Trades's Avatar
Originally Posted by TouringBubble
Since you have an 05, you'll have to wire up a separate switch to manually change maps. Tephra has built map switching code and a new version with boost control should be out soon. It is possible ... it just takes some work.
If you are interested in being able to switch between different sets of maps (basically have 2 different tunes for your car) I have a how-to article on how to make the switch in my signature. I also pre-make them for the busy people in the world.
Mellon, are you gonna use the map switching patch for your race gas setup so you can switch to a pump gas tune on the fly?
Old Feb 27, 2008 | 06:02 AM
I doubt it, I like to keep things as simple as possible...it would be different if I ran around with two tanks of each fuel and felt it necessary to swap from one type to another for a race.
usually I know ahead of time what I'm going to be getting into and come armed with the appropriate fuel/map.
Old Feb 28, 2008 | 09:18 AM
20Grockit's Avatar
do i have to have the jdm map sensor to control boost??
Old Feb 28, 2008 | 09:28 AM
TeStUdO's Avatar
No, you use that to log boost.
Read THIS for great ECU controlled boost information.
Old Feb 28, 2008 | 03:11 PM
20Grockit's Avatar
ok i will man. thanks alot.
Old Feb 28, 2008 | 03:27 PM
20Grockit's Avatar
nice little write up man. thanks for the info. im gonna go check into that stuff at the local chevy/gmc dealer. let me get this right though just so im on the same page. all i need to get is a boost solenoid and the pigtail and the other little odds and ends mentioned in your write up?? so do i need to get an upgraded map sensor so i can log boost???
Old Feb 29, 2008 | 07:36 PM
20Grockit's Avatar
anyone know where to find the direct replacement jdm 3 bar map sensor??
Old Feb 29, 2008 | 08:26 PM
RazorLab's Avatar
https://www.evolutionm.net/forums/sh...58&postcount=1
