Newbie-Need Help on getting Evoscan 2.1 running
Old Feb 23, 2008 | 10:59 AM
gunhaha's Avatar
Bought a Tactrix cable, new laptop with Vista, and registered/downloaded Evoscan 2.1 and Ecuflash this past couple of days.
Now, how do you get this thing to even start working/logging.
I plugged in the cable to the ports, start the car, open Evoscan and get this error of not finding port COM1 and a voice message "Link disengaged". It seem to work for about half a second before this error/message comes up.
And this is after I have went back to my laptop control panel device manager and set the "OpenPort 1.3 Mitsubishi (as Serial Port) (COM1)" to COM1.
Am I missing something here?
Do I have the wrong cable?
or setting in Evoscan?
The baud rate in Evoscan is at 15625; does this need to be changed to another setting?
I know there is a thread about Evoscan 2.1 issues but those or more advanced issues. Mine is just on getting this thing to run.
Thanks,
gunhaha
Old Feb 23, 2008 | 11:44 AM
xpro's Avatar
same here.i can get new evoscan to work.
never had any problems with previous version,but with the new one im have the same problem.its telling me that unable to open the port????
help guys
Old Feb 23, 2008 | 11:52 AM
gunhaha's Avatar
Unfortunately, I only have the latest version, 2.1 as I just registered yesterday.
Is there a way to download the previous version?
The 2.1 shows Evoscan USB Cable as the selected in the device setup.
Do you think the new version will work only on Evoscan cable and not with the Tactrix?
gunhaha
Old Feb 23, 2008 | 12:13 PM
xpro's Avatar
you have to go in device manager and change ports for your tactrix cable.its under open port.should work then,give it a try if you want.
mine still doesnt work tho...
Old Feb 23, 2008 | 12:38 PM
kreionic's Avatar
No you dont evoscan will find what port the tactrix is using. The only com port thast needs to be messed with is your wideband port. I am willing to bet both of you have wideband checked without having a wideband hooked up to your PC
Old Feb 23, 2008 | 01:17 PM
ChuckP's Avatar
Yup. that will do it.
Old Feb 23, 2008 | 03:40 PM
gunhaha's Avatar
Kreonic,
Thanks. Yes, the Innovale LM1 is enabled under the wideband tab. The only way to get it off is to check the Create System debug and Create serial log at the bottom under the wideband tab. I did this and it worked and start logging.
Strange thing is when I close and open Evoscan again, it defaults to Enable that Innovate LM1 line under Wideband tab again. But now it does work and the error does not come up.
Xpro-try doing this and it most likely to fix your problem also.
gunhaha
Old Feb 23, 2008 | 09:02 PM
Jack_of_Trades's Avatar
Uncheck everything on the evoscan list except rpm and see if it connects. If it does, its either the wideband thing (that has caught me off guard a few times) or there is something wrong with one of the other 'checked' parameters on your list. Let us know if you get it to connect.
Old Feb 23, 2008 | 10:03 PM
gunhaha's Avatar
Yes. I finally get it to connect. You are correct that its the wideband being checked.
I played around the tabs and probably did something that caused all the items to become unchecked and that's when I was able to connect.
Now I need watch this section of the forum to learn the Evoscan functions.
Thanks for the help.
gunhaha
Old Mar 14, 2008 | 04:32 PM
Dyrexion's Avatar
have any of you noticed or experienced only being able to select comport 3?? on version 2 i could only get my ZT2 to work on comport 5. any similar experiences??
Old Sep 28, 2008 | 06:39 PM
Spish's Avatar
Ok, I'm having similar problems, I get "USB Device not responding". I've got COM 3 checked, BaudRate is 15625, I unchecked everything except RPM and still nothing, so uncheck EVERYTHING and it goes green in the Event log until i check something. I have the new Tractrix 2.0 and its lit up so I know its working, plus when I plug it in to the comp it beeps like new hardware installed. I can use Ecuflash to download but I can't datalog using Evoscan. HELP
Old Sep 29, 2008 | 12:44 PM
xpro's Avatar
i think com1 should be your main port in evoscan afaik
Old Sep 29, 2008 | 07:04 PM
Spish's Avatar
I tried Com port 1 and it still wont work. Any ideas???
Bewstzalot
Jul 7, 2017 01:35 PM
monkeyevo
Jul 20, 2011 11:09 PM
gunhaha
Mar 5, 2009 06:39 AM
PeteyTurbo
Apr 2, 2008 11:02 PM
