Using ECUflash
Old Feb 27, 2008 | 12:00 PM
rolly1818's Avatar
Registered User
Question Using ECUflash
is there anyway to reflash an ECU that is out of the car?
reason being i want to reset my ECU to stock, but my car is down so to speak!
Old Feb 27, 2008 | 02:14 PM
roger smith's Avatar
ECUFlash doesn't need a running engine to work. Is that what you mean by your car is down? Or do you have the wiring harness out of the car?
Old Feb 27, 2008 | 02:55 PM
rolly1818's Avatar
Registered User
Where exactly is the ECU in the car? (in detail please)
if i have the ECU in my hand (disconnected from the car), the car does not even have an engine, lol
i need to flash it now but how?
Thanks guys
Old Feb 28, 2008 | 04:08 AM
rolly1818's Avatar
Registered User
anyone?
Old Feb 28, 2008 | 04:28 AM
spdracr's Avatar
y would u need to flash it if it doesnt have an engine lol and the ecu is in the glove compartment if u climb under there u see the pins etc. all that has to be hooked up so u can plug into the port on the drivers side with a tactrix cable.
Old Feb 28, 2008 | 05:41 AM
Jazzie604's Avatar
If the wiring harness is intact, you should be able to plug the ecu back in, hook the battery up, and flash from there. To flash the ecu off of the car, you would have to build a dedicated harness to connect to the ecu properly. MAKE SURE the battery is fully charged, and you may even consider putting a trickle charger on it while you are working, just in case. The computer wont know the engine is not in the car, it will only know its not getting readings when you key on.
****disclaimer**** be careful, dont screw up cause its not my fault****
TheOtherLancer
Jul 8, 2016 06:19 AM
Insanity Evo
12
Jun 20, 2014 06:33 PM
mcthar
Jun 1, 2012 01:25 PM
eclipzed
Dec 22, 2008 02:59 PM
omtorlak
Feb 26, 2007 01:57 AM
