need help: new xml files for upcoming ECUFlash release
Old May 19, 2008 | 07:20 AM
  #76
mrfred's Avatar
Can one of you to send me a revised table with the on/off combined?
Old May 19, 2008 | 04:16 PM
  #77
SWOLN's Avatar
Sorry for the newb question, but is there a general release date for Ecuflash, with these additions?
Old May 19, 2008 | 04:55 PM
  #78
mrfred's Avatar
Haven't asked Colby, but I would guess within a month.
Old May 21, 2008 | 05:44 PM
  #79
mrfred's Avatar
Spoke to Colby today:
- tephra, he is going to work on your request. May not make it in this release, but he will get something together.
- He had a few minor requests on the organizational structure of the updated xml files. I've made changes to accommodate his request. I will post that as soon as I get an updated definition from someone for the Lean Spool Relay On/Off time.
- I took a shot at the Lean Spool Relay On/Off Time definition. Here is what I have:
Code:
  <table name="IC Relay Timer On/Off Time" category="IC Spray" type="2D" scaling="TimeSec">
    <table name="Condition" type="Static Y Axis" elements="2">
      <data>On Time</data>
      <data>Off Time</data>
    </table>
  </table>
Can someone please make sure that this works and make sure that the name is appropriate?
- We spoke a bit about the Open Port 2.0 cable and the Evo X. The new cable will actually have a processor in it, and will have data logging capability all by itself! Cool, eh? It has a microSD card slot to store logged data. Evo X ECU is an M32R. If anyone has heard any different, they are probably confusing it with the drive-by-wire control processor on the card.
Old May 21, 2008 | 06:30 PM
  #80
dudical26's Avatar
Code:
    </table>
  </table>
Wow being able to log straight to an SD card with the cable itself, that is downright awesome.
Old May 21, 2008 | 06:43 PM
  #81
tephra's Avatar
thats what I want - logging without a laptop
thanks mrFred, ps its intercooler relay time not lean spool :P hehehe
I will test that XML and let you know.
Old May 21, 2008 | 08:04 PM
  #82
mrfred's Avatar
The cable will work with Evo 8/9s too.
Old May 30, 2008 | 03:18 PM
  #83
mrfred's Avatar
Alright, I went ahead and made a few last changes to the evo9base.xml file and did the needed corresponding changes to the 885900XX.xml files. Here's what I changed:
- Open Loop Throttle Low/High Load -> Open Loop Throttle #1/#2
- Added proper scaling for Open Loop Throttle tables
- Changed names of Periphery bit tables.
- Added the ICS Relay Timer On/Off table
- Added a separate section for JDM boost control
- Renamed the boost control categories so that the JDM boost stuff is separate from the non-JDM boost stuff.
I swear this is the last revision for a while, so if you guys can update your xml files, and post them, then I can get them to Colby for the next release of ECUFlash (which is likely to be soon because the version he just released has a bug that causes it to crash when IDA is running.)
File Type: zip
File Type: zip
Old May 30, 2008 | 05:22 PM
  #84
RazorLab's Avatar
mrfred,
I noticed the real idle tables aren't included in those?
Old May 30, 2008 | 05:25 PM
  #85
RazorLab's Avatar
Also noticed alot of grayed out tables with those files. (1.35)
Old May 30, 2008 | 05:36 PM
  #86
mrfred's Avatar
Originally Posted by razorlab
mrfred,
I never got around to adding those because I didn't follow that thread so closely. I'll get it in the next release of ECUFlash.
For the USDM Evo 9, only the "Turbo Boost JDM", "Turbo Anti-Lag", and "IC Spray" items should be grayed out. The bit representation of the Periphery values will be screwed up unless ECUFlash 1.35 is used.
Old May 30, 2008 | 05:59 PM
  #87
RazorLab's Avatar
I did a fresh install of 1.35.16 and this is what is greyed out:
Old May 30, 2008 | 06:02 PM
  #88
mrfred's Avatar
Try changing the developer level. I raised the developer level on a bunch of the specialized stuff. :-)
Old May 30, 2008 | 06:11 PM
  #89
RazorLab's Avatar
Already checked, it's on developer.
Old May 30, 2008 | 06:18 PM
  #90
Jorge T's Avatar
if you change the individual greyed out tables to "advanced" level they bold out again, it behaves the same on 1.34.
