evo scan and ecuflash questions need help
Old Mar 28, 2008 | 09:06 AM
el brusco's Avatar
I tryed to datalog my evo9 using evoscan (latest version) and tactrix cable and couldn t get it to work it connect succesfully and reconnect 1 sec later and dissangaged connection! and the excel files for that +/- 1 sec of log gets created but is unavailable (file doesn't exist). can anyone help? I know I am probably doing or forgetting something stupid so please you guys don't be too hard with me it is my first attempt!
Also, I can't get my ecu flash to work: when I try to read/download ECU a blank window opens and nothing happens, can anyone helps?
Sorry for asking stupid questions but I am trying to learn and read a lot but I couldn't figure what I did wrong.
thanks
Old Mar 28, 2008 | 09:40 AM
el brusco's Avatar
help please
Old Mar 28, 2008 | 12:25 PM
Mr. Evo IX's Avatar
video for ECU Flash
http://www.youtube.com/watch?v=AigoMPNtqAA
As far as logging what items do you have selected in EvoScan? If you don't have a wideband you can't log wideband, if you havent setup your ECU for 2byte load / rpm / airflow then you can't select those.
Try logging with just these selected
battery level
throttle position
engine rpm
injector pulse
airflow hz
air temp
speed
load calculated
knock sum
Old Mar 28, 2008 | 06:06 PM
el brusco's Avatar
thanks I got the evoscan problem fixed my baud rate needed to be set at 62500,
but when I open the log on excel they re all mixed up, how can you change that? (maybe because I am using the latest excel version?)
Old Mar 28, 2008 | 08:12 PM
codgi's Avatar
What do you mean all mixed up? Its not to do with the latest version of Excel that is for sure.
Old Mar 30, 2008 | 07:58 AM
el brusco's Avatar
I mean all the logs look like that
4,2008-03-28,13:48:11.16500,0.428,,0,7750,,,316.4,69.8,-20,,,319.8,,,,,,,,32.768,0,,,,,,,38,,,,,,,,,,,,,10 240.3125,3499.776,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, 17: 248
that would be one line all written in cell A5! Instead of having the values in different cells?
Old Mar 31, 2008 | 01:42 PM
el brusco's Avatar
help please
Old Apr 1, 2008 | 12:26 AM
codgi's Avatar
The logs are stored as CSVs (Comma separated values) and thats what each line looks like. If excel is opening the log as a CSV (ensure the extension has not been changed) and showing each line as a value instead of a row then Office is probably just horked. Uninstall/re-install or try something else that opens CSVs such as Open Office maybe?
Old Apr 1, 2008 | 11:17 AM
el brusco's Avatar
I foud a way to open them as regular excel file (import external data as text, select the cvs file , then select comma) and it finally opens each commas as a different cell... codgi thanks a lot for the help!!!
But now I tryed to do some log and all the values are off
RPM looks like that that was a 2500-5000 rpm pull in 3rd
4000
62.5
875
4000
31.25
187.5
62.5
7750
218.75
62.5
875
218.75
etc...
TPS the same
9.01960784313725
50.1960784313725
0.392156862745098
16.078431372549
97.2549019607843
1.96078431372549
9.01960784313725
16.078431372549
and all other values are similar reading 300+ knock sometimes etc
I am really confused (baudRate is set at 62500 and timeout 1000)
help again please
Old Apr 1, 2008 | 09:17 PM
el brusco's Avatar
help please do I need to calibrate somethig why even RPM is totally off?
Old Apr 2, 2008 | 12:54 AM
codgi's Avatar
Is your ECU setup to use 62500 as a baud rate? Did you make the mods to the rom to allow this?
Old Apr 2, 2008 | 01:32 PM
el brusco's Avatar
thanks codgi I change it back to 15625 and it all works fine!!!
Now I can't get ecuflash to read my ECU! I click on read ECU and a new window opens and stays blank???
GTijoejoe
Jan 8, 2024 08:58 PM
johntrav
May 7, 2014 08:45 AM
kyoo
Feb 25, 2011 05:48 PM
DaJackson
Jul 3, 2010 11:02 PM
AlwaysinBoost
Sep 14, 2009 01:01 PM
