EvoScan2.1 Problem - Link Succesful... NO DATA
Old Apr 6, 2008 | 02:09 PM
jid2's Avatar
I got a new computer and loaded up Evoscan 2.1 but I'm having problems. Everything seems to be OK, I connect to my car and "Start Logging", I get the link complete message and the timer starts.
But when I pull up the data or make a graph everything is zero'd out. I have plenty of values checked to monitor but I come up with no data, just flat lines.
Anyone have some insight. This is a fresh load of Version 2.1 on a new 64 bit windows xp machine.
I have version .99 installed on another computer and it still works great. I'm afraid to install 2.1 on that machine and screw it up.
Old Apr 7, 2008 | 05:00 AM
recompile's Avatar
Is "Log To File" enabled?
How are you looking at the log? Try opening the CSV file with Excel or OpenOffice.
Personally, I use v0.99 because it's the most consistent.
Old Apr 7, 2008 | 09:59 AM
jid2's Avatar
I have checked the CSV file in excel and it's full of 0's, so the data isn't making it there. I'll check the "Log to File", where is that option located ( I don't have it on this work computer).
Old Apr 7, 2008 | 11:54 AM
merkzu's Avatar
2.1 did the same thing for me, I went back to 2.0
Old Apr 7, 2008 | 07:48 PM
3gturbo's Avatar
Im back to version .97 and maptracer.exe since I cant even scale the injectors in 2.0 or later without it screwing something up.
Old Apr 7, 2008 | 10:32 PM
jid2's Avatar
I went back and installed v2.0 instead of v2.1 and still no luck. Both 2.0 and 2.1 record no data, I checked to make sure I was logging to file as well.
I did load v.99 unto my new computer and it works, but I like some of the new feature of 2.1 so I'd like to get it working.
Anyone else have insight?
Old Apr 7, 2008 | 10:54 PM
mrfred's Avatar
A few questions:
- Are you using the Data.xml file that came with EvoScan 2.1?
- Have you tried progressively disabling what items are logged?
Old Apr 8, 2008 | 02:56 AM
3gturbo's Avatar
Maptracer.exe uses the afrmap to map out the cells what parameters are absolutely needed for maptrace to work in Evoscan? My latest attempt I tried reinstalling 2.0 and it worked until I changed the injector scaling in the ecuload from 513 to 860. That one change breaks the logger completely.
Old Apr 8, 2008 | 08:17 AM
jid2's Avatar
Originally Posted by mrfred
A few questions:
I made a clean install of EvoScan 2.1 without touching anything and it didn't work. I've also tried adjusting the XML file for the standard fixes of formula values - but that's it.
I'll try only selecting a few items.
Old Apr 8, 2008 | 01:59 PM
jid2's Avatar
I tried logging only TPS and RPM today at lunch = nothing! Still can't get 2.1 to record any data even with a "link engaged".
Do I need to have my Laptop plugged into power for 2.1? Just a crazy thought?
Old Apr 8, 2008 | 03:06 PM
cossie1's Avatar
Do you have an LC1 connected to the laptop too ?
Mine works fine, unless I connect the serial connection to my LC1, then evoscan seems to go weird and gives me no info or just 2 readings (which are made up) i.e 338.8 knock counts at 160 load lol.
If I disconnect the serial to the LC1 and fire up evoscan again it works fine.
I should point out, evoscan 2.1 worked 100% fine with the LC1 until I installed 2.2, since then i've had the above issue, and it's the same with 2.0, 2.1 and 2.2
Old Apr 8, 2008 | 07:04 PM
jid2's Avatar
I don't have an LC-1 connected, it does this with just the Tactrix cable.
Old Apr 8, 2008 | 08:26 PM
mrfred's Avatar
You get row after row of zeros? Can you post an example?
Old Apr 8, 2008 | 09:48 PM
nonschlont's Avatar
im almost ashamed to ask this, but "TPS" is this throttle position? cause if its not, I dont have it on my list... (2.1)
Old Apr 8, 2008 | 10:27 PM
jid2's Avatar
Here are shots of the EvoScan graphs and the CSV file. The only selected values were RPM and TPS to keep it simple.
Yes TPS is throttle position sensor.
