Questions about GM 3 Port Tuning
BTW, Razor, did you rescale the other side of the table? That's a lot of zeroes in the middle.
Haha, I don't think it's enough to drop it all the way to 12psi. If you are overboosting so much that you are at the end of the table, you have other issues...
(not pointing at you, just saying in general)
That same error correction table is used on a local autox SM drivers Evo 9 who hasn't seen a problem yet.
(not pointing at you, just saying in general)That same error correction table is used on a local autox SM drivers Evo 9 who hasn't seen a problem yet.
That same error correction table is used on a local SM drivers Evo 9 who hasn't seen a problem yet.
(not pointing at you, just saying in general)That same error correction table is used on a local SM drivers Evo 9 who hasn't seen a problem yet.
EDIT: I just looked at my ROM and guess what? I have 0 in the top cell.
I must have changed it back at some point.
When I was getting it all set up (and my correction interval was 1) I was having wild enough swings that it was getting stuck in underboost. Although I had the top three cells zeroed. Once I got it dialed in, it stopped doing that. I changed them all to 0.5 then. It wasn't gonna hurt anything because I never really see those cells.
