worried about my tune
Old Apr 10, 2008 | 02:01 AM
  #31
JohnBradley's Avatar
Brian very good point. The boost really hadnt changed more than 2-3psi as the MBC on this car was maxxed more or less.
Old Apr 10, 2008 | 09:10 AM
  #32
Mr. Evo IX's Avatar
Originally Posted by tephra
interesting those maps JB - basically reitterates the map difference required on the dyno vs street right?
He's referring to difference in fuel type 104 vs 93 oct. I think what JB was saying is that your fuel may be different enough from ours that your map 'looks' lean but in fact is fine for the fuel you tuned it on.
I'm betting your alright but I appreciate your caution. I would start with the exhaust leak and possibly look for another WB to quantify your results.
Old Apr 11, 2008 | 01:25 PM
  #33
Mr Evo IX hit it on the head. I was also trying to say that depending on how load is placed on the car it seems that there are different affects to what the AFR is independent of the map setting ... or where it "should" be
Old Apr 12, 2008 | 02:00 AM
  #34
tephra's Avatar
ok chaps - finally redid the exhaust (6th time) and did a proper free air cal at the same time.
here is the resulting 3rd gear pull, also there doesn't appear to be any fuel smell anymore, so i take it the exhaust isn't leaking yay!
so does that look about right now? will I need to richen up the map if I put a 3" catback on?
Old Apr 12, 2008 | 02:16 AM
  #35
RazorLab's Avatar
So your logged AFR went from 10.6 at 6500 to 11.3 or so at 6500 just by fixing the leak?
Old Apr 12, 2008 | 03:23 AM
  #36
tephra's Avatar
yes, and a proper free air calibration!
Old Apr 12, 2008 | 01:02 PM
  #37
And this was still on the map that you posted the screenshots of? IF so, dont fret about how the map looks, worry only about the results. If you wanted the map to look "right" you could alter the scaling of your stockers and change the global fueling. That would be alot of work though, so I stand by my original advice and just do what it takes...you'll get it
Old Apr 12, 2008 | 05:19 PM
  #38
tephra's Avatar
yes - the only reason I asked in the first place was because that map already looked a little lean... i didn't want to lean it out futher..
Burnhad91
Aug 11, 2016 03:06 PM
andres_d85
Sep 14, 2009 04:29 AM
mx4life85
229
Aug 1, 2008 09:59 AM
SteVenQDZ
For Sale - Cars For Sale
23
Mar 13, 2008 04:15 PM
Jeff_Jeske
Jun 26, 2007 08:43 PM
