how-to: Log AFR from the LC-1 w/o a serial cable
Old Feb 22, 2010 | 10:45 AM
  #331
tscompusa2's Avatar
i have the aem uego + aem oil + aem boost. can i splice all 3 blue (serial logging) wires together and get them all logged via one serial cable?
edit: nm seen another thread about it.. ill log boost by other means.
Old Feb 22, 2010 | 11:24 AM
  #332
logic's Avatar
Originally Posted by qnz
correction: it should be 0.05882353*x+6.5
Good catch, nice little typo there. Fixed.
Old May 11, 2010 | 03:08 PM
  #333
jrhonda's Avatar
I had an S2000 and I just tapped into the existing rear 02 sensor line as close as possible to the ECU for my wideband that I had installed on it. Can't we do the same here without having to buy the female ECU pins?
Or if your feeling bold, just cut the ECU wire thats associated with the rear 02 ECU input and connect the wideband line?
Just wondering if I am missing something here.
Old May 11, 2010 | 03:19 PM
  #334
irishone337's Avatar
I don't know how the hell I missed this old of a thread. I must have searched for two hours on how to log without the cable. This is some great information man. I guess I just wasn't searching the right things.
Old May 11, 2010 | 09:10 PM
  #335
jdmevo123's Avatar
hi guys,
i have a jdm evo 8 that has the same pinout diagram as the evo 9. I wired my aem white cable into pin 73 and changed MUt3c to 8409. I call this in evo scan and have the formula for the wideband in as well. However I am constantly ready a 9.8 and it does not change.
Am i right with MUT3c or should I be using MUT12?
Old Jun 6, 2010 | 03:19 AM
  #336
drifterific's Avatar
So what I am not understanding is what output would go to the gauge its self? The instructions say that the brown output 2 goes to the gauge and the yellow wire is analog out 1. So would i connect yellow analog out 1 to the gauge (DB series) and brown analog out 2 to the ecu? Also another question is can i program both outputs to have the same voltage reference?
Old Jun 6, 2010 | 06:00 AM
  #337
leecavturbo's Avatar
you can use either wire they are both the same output types and both configurable individually
Old Jun 6, 2010 | 02:27 PM
  #338
Ok thanks for the info. The reason I was asking is because I came across some info online that said the yellow was for narrow band output and that it would be bad to set both wires to to show the same voltage.
Old Jun 6, 2010 | 02:31 PM
  #339
page 6 is all the visual confirmation you need
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
Old Jun 7, 2010 | 01:28 AM
  #340
Thanks for the link. It looks like I can program analog output one to match analog output 2 through the LM Programmer so that my gauge will be accurate.
Old Jun 9, 2010 | 05:14 PM
  #341
Pete399's Avatar
I installed a FJO WB using this rear O2 procedure and it was working but when I updated the scaling formula it's now just reading 14.8ish. It will go +-0.1 every 30 sec or so. I tried the base LC1 formula again and nothing changes. Also disabled the rear O2 sim from V7 and it reads the same. Even when I re-flashed the sim enabled no change. I'm getting the correct voltage to pin 75 on my ECU (Evo 8) and can see the change on the muti-meter. I'm using the latest version of EvoScan that has the rear O2 WB definition already there, labled as LC1 WB mod. I tried to reload the xml def to the EvoScan data xml from this "how to" and it came up as all numbers. Anybody else go through this?
Old Jun 10, 2010 | 12:41 AM
  #342
vmrevo9's Avatar
Veteran: Air Force
have you looked closely at the formula in evoscan? make sure its exactly the same as what you need!
Old Jun 11, 2010 | 03:46 PM
  #343
Pete399's Avatar
After some more troubleshooting I still can't get a handle on this. I just bought the latest version of EvoScan and still doesn't work. The xml def in EvoScan is correct and the formula is correct for the LC1 which I now reinstalled on the car. All EvoScan is doing is logging the initial reading and never updates the AFR/input. I'm getting 4.8 volts from the ECU pin 75 when I disconnected it from my analog AFR input. My WB analog output volt varies as it should for the 0-5v scale. Should there be 4.8 volts coming from the ECU where the WB input voltage is going? I have MUT 12 set to 8409 and rear o2 sim enabled thru V7 rom...kinda lost here.
Old Jun 13, 2010 | 04:25 AM
  #344
i don't think you should have 4.8v there!
not much help to a solution i know
Old Jun 17, 2010 | 11:37 PM
  #345
rgar's Avatar
Since there is no Data.xml file in evoscan 2.7, should i put this
(<DataListItem DataLog="Y" Color="" Display="Wideband AFR" LogReference="WideBand" RequestID="12" Eval="0.05859*x+7.35" Unit="AFR" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="22" ChartMin="0" ChartMax="22" ScalingFactor="1" Notes="" Priority="1" Visible="false" />)
in the mitsubishimuttII.xml?
