how-to: Log AFR from the LC-1 w/o a serial cable
Old Jun 18, 2010 | 06:54 AM
  #346
rgar's Avatar
Also if I'm doing this with v7 I still need to change the MUTT12 address correct?
Old Jun 23, 2010 | 04:44 PM
  #347
jdmevo123's Avatar
Hi Guys,
I am in desperate help, I am still reading 9.8 steady on evoscan, I have a JDM harness so 3 plugs, the white wire is going to the pin 73 and I have setup evoscan correctly.
Has anyone got any Ideas on why I cannot get this working? Anyone experience this problem.
I have changed mut12 and mut 3c to 0x8409 and still nothing if I switch between the two.
Please help, I need to finish my tune.
Thanks
Dale
Old Jun 23, 2010 | 05:33 PM
  #348
tephra's Avatar
are you using tephramod? otherwise 0x8409 wont do anything
Old Jul 13, 2010 | 07:44 PM
  #349
wizzo 8's Avatar
Where should I mount the control box for the Innovate WB? Hide it behind the carpet Im assuming? Also couldnt you just cut the factory rear o2 sensor connector. Then solder the brown wire from the WB to the correct wire that goes to the Ecu through the factory harness? Would seem easier
Old Aug 29, 2010 | 11:35 AM
  #350
VGergo's Avatar
can we log wbo2 via rear o2 using the Tephra V7 9653 ? Shoud I change anything in the MUT table or just log MUT 12 with the right Eval in Evoscan ?
Old Aug 29, 2010 | 11:40 AM
  #351
wizzo 8's Avatar
Not with the factory sensor. Its a narrow band sensor.
Old Aug 29, 2010 | 01:12 PM
  #352
VGergo's Avatar
oh yes ofcourse an aem ugeo wired in the rear o2 pin . just what to do with the MUT table ?
Old Aug 30, 2010 | 03:01 AM
  #353
VGergo's Avatar
In the v7 9653 MUT 12 is 8409 too ?
Old Sep 13, 2010 | 02:34 PM
  #354
binarysleep's Avatar
P0141
First, THANKS for the write up! Very helpful information.
I would humbly suggest you incorporate the "O2 heater sim" information for people who do not use the tephra mod and decide to edit their xmls directly (option 'b' )
https://www.evolutionm.net/forums/ec...sim-patch.html
Otherwise you'll get a P0141 when replacing the rear stock O2 with a WBO2.
Old Sep 22, 2010 | 08:17 PM
  #355
teribble's Avatar
fixed
Old Sep 22, 2010 | 08:27 PM
  #356
teribble's Avatar
EDIT-Human error
Old Oct 2, 2010 | 11:14 AM
  #357
mchristian's Avatar
Log AFR w/new AEM 8.5 to 18:1 (Analog Face 30-5130)
Has anyone successfully used the new AEM Analog Face (30-5130) wideband for logging w/o a serial cable?
I was looking at the docs and the transfer function for the output is different than the popular digital AEM wideband (30-4100).
Can anyone help me with the proper formula for this gauge?
Old Oct 2, 2010 | 02:06 PM
  #358
VGergo's Avatar
yes I can with eval : 0.03913*x+10 logging MUT 12 .
Old Oct 3, 2010 | 11:20 AM
  #359
Chino1's Avatar
are you on a v7 rom? i cant find mut12 but i see where mut3c has 8409 in it. still not getting the right readings in evoscan though.
who out there is logging uego using mut3c on a evo 9?
Old Oct 5, 2010 | 02:44 PM
  #360
VGergo's Avatar
Yes I'm on v7 but Evo 8 and didnt change anything in the Mut table just logging mut12 with eval : 0.03913*x+10. I can log same afr as on the gauge . Also have MrFred closed loop control by wbo2 afr patch where i calculate the ml bl/ml values from that eval.
