DV flutter = knock?
Old Apr 10, 2008 | 03:07 PM
SoCalRedLine's Avatar
^seriously....but then again a new turbo would be nice
ive checked all the hoses, and theyre working properly. I think its just not enough pressure to keep the valve shut.
Old Apr 10, 2008 | 03:11 PM
Jack_of_Trades's Avatar
Pull the DV and check the seat inside for any debris or wear.
Old Apr 10, 2008 | 03:34 PM
^ill check when im out of work and report back.
Old Apr 10, 2008 | 03:40 PM
RazorLab's Avatar
Originally Posted by SoCalRedLine
if you knock 3° then it pulls 1° of timing out across the whole RPM range.
1* over the whole rev range? If that is the case, then you have other issues.
a little spike of 3 knock should just pull timing at that area and be fine once it clears up. If you have 3 counts of knock through the whole rev range the tune needs to be attended to.
As far as all these little knock spikes... you will drive yourself crazy tending to them. The car sees noise all the time and if you try to clean it all up, espically the random stuff you are going to go insane.
I've been trying to see what makes the car knock now that I have the CEL light on. You would be amazed at what can cause quick 1-3 knock counts. Totally stupid stuff like running over a rock in the road, driving through a sandy area with little pebbles hitting control arms, etc. Little tiny jabs of the throttle at specific throttle openings, WOT and catching air off things in the street , etc etc
I personally do not concern myself with little sporadic 1-3 knock count blips. Now, knock that blips and sustains is something to look into, even more so if it's not random.
Old Apr 10, 2008 | 05:05 PM
Words to live by when tuning an Evo
Old Apr 10, 2008 | 05:19 PM
dbsears's Avatar
So would something like a Tomie or Works dv work better because its less likely to crack open at very low boost. Mine flutters something in 5th or 6th then the car bucks (compressor surge). I would really love to remedity the problem as its somewhat annoying. I was told by one of the WORKS guy their diverter valve fixes this problem but I want to see others opinions on this.
Old Apr 10, 2008 | 06:14 PM
RazorLab's Avatar
it does it in 5th or 6th at low rpm right?
The works bov does it as well. The works is just a Tomei bov.
Old Apr 10, 2008 | 06:57 PM
dbsears's Avatar
Yea it does it in 5th and 6th. Bummer...so the Tomie/Works valve doesn't cure it. Oh well, guess I will just drive around it.
Old Apr 10, 2008 | 07:03 PM
RazorLab's Avatar
Do you have the stock accordian intake tube or a aftermarket one?
Old Apr 10, 2008 | 07:19 PM
dbsears's Avatar
Stock accordian one. The only intake mods I have are the BMC drop-in and the Rexspeed CF snorkel. Maybe I have a boost leak? My car just turned 30k miles so the stock DV shouldn't be worn out yet I don't think.
Old Apr 10, 2008 | 08:24 PM
The Greddy 'Type RS' blow-off valve has NO compressor surge issues when using the large spring (it comes with a small AND large spring installed so you need to remove the small spring) and can hold 30psi like a champ.
Old Apr 11, 2008 | 12:08 AM
codgi's Avatar
I thought there was a post on here a few years back that showed going to the single spring mod with this BOV was actually detrimental
Does anyone else remember this?
Old Apr 11, 2008 | 03:03 AM
I actually bench tested this setup and there is NOTHING wrong with it what-so-ever. What would be bad about it? It doesn't compressor surge and it holds boost. Thats all its supposed to do
Here:
https://www.evolutionm.net/forums/sh...1&postcount=94
Old Apr 11, 2008 | 06:47 AM
mrfred's Avatar
I have been trying to get rid of my partial boost ( > .5bar) to full boost knock, and noticed that nothing i did to the timing table would get rid of it. I have already made room around all my heat shields, and made a nice open area for the DP to sit, and am still getting some kind of knock when i go from partial to full boost.
Today (and last night) i was noticing that the Diverter Valve will flutter at any level of boost from 0-.5 bar. Then i tried making it flutter over and over, and the knock light would turn and i would get 1-3 counts of knock on occasion. I havent been able to consistantly re-produce the knock, and im thinking this might be why.
has anyone else had this happen? too much flutter will cause 1-3 counts of knock?
I've just noticed that in the last few days, I hear a very faint fluttering sound from the engine compartment, and the engine feels like it has a very slight stutter. Seems to happen in the lower gears, mainly as I roll through 3000 rpm when I'm just getting started in the morning. I'm usually pretty light on the throttle in the morning, so the intake manifold was probably under vacuum conditions. It doesn't happen in 4th thru 6th. At first I thought it was just a cold misfire from crappy OEM plug wires, but now I'm wondering if its DV flutter. Is that what it feels like?
Kinda confused though because I always heard that the stock Evo MR DV was very good and didn't need to be replaced.
Old Apr 11, 2008 | 07:57 AM
bnice01's Avatar
good advise
