installing new turbo tonight and need tuning baseline hlep
Old Apr 12, 2008 | 02:30 PM
spooch's Avatar
im putting in my ets 57trim kit tonight, goign to use stock injectors,stock cams and 93.. can anyone give me a baseline ecu flash map so that I can be able to drive the car and drive like an old women and not hit more then 4 or 5psi of boost and not have to worry that my car will blow up
Car will get tuned when the cams and meth kit come in but tonight/2morow morning is myonly opportunity n time to put the turbo kit in for a while, busy schedule ahead of me...
if anyone can help me out thatd be great, i have ecuflash and mitsulogger
Old Apr 12, 2008 | 02:48 PM
Boltz.'s Avatar
FCOTM Winner
If you still are on the stock injectors and don't get into more than a couple part throttle psi youll be fine on the current tune.
end thread/
Old Apr 12, 2008 | 02:52 PM
spooch's Avatar
alright, should i change anything at all in ecuflash as a safety measure? i will just be driving the car to and from work but there is an uphill part that i may have no choice but to hit 5-8psi for 10 seconds or so
Old Apr 12, 2008 | 03:17 PM
RyuEvoIX's Avatar
Just keep the boost at wastegate pressure.
JohnBradley's Avatar
Put a stock timing map in it for the time being if you are worried about it. 5-8psi isnt gonna hurt anything as the airflow from that turbo wont match a wound out stocker for quite awhile (In the range of 19-20psi), and even then it will still be colder air.
Old Apr 12, 2008 | 03:34 PM
nasty8evo's Avatar
you will be fine just take it very easy.
Old Apr 12, 2008 | 08:46 PM
RazorLab's Avatar
Drop current ign map 2*. Run wastegate pressure. Richen the fuel map up by 2 clicks.
Don't got WOT.
Should be fine.
chiminican
Jul 11, 2009 07:54 PM
03redtype-s
Oct 6, 2008 12:38 AM
spooch
12
Apr 1, 2008 05:59 PM
DangerousDan
Jan 1, 2008 03:20 PM
Warrtalon
72
Jan 24, 2006 04:50 AM
