show your designed load curve
Old Apr 15, 2008 | 10:13 PM
lemmonhead's Avatar
well that makes since with the turbine, I never ran my car for great lengths of time doing that so dont have any data. I will have to do some experiments at the track with the different setups, i will try 25psi peak-taper to 19-20, then try 25psi peak-taper to 23. thanks guys.
Old Apr 16, 2008 | 01:45 PM
TouringBubble's Avatar
I see what you are saying with the TBEC. that is a valid point. TBEC does carry over when you let off the throttle.
Do you have another solution for climates like mine, where the temps change drastically between seasons?
I've weighed the options I know of and I'm willing to put up with a small spike if it will allow me to not require a re-tune every season.
Old Apr 16, 2008 | 02:54 PM
lemmonhead's Avatar
ya its better not to have to retune, a spike wont hurt afterall you do have boost limit table to protect you for big overboost spikes.
Old Apr 19, 2008 | 12:16 PM
nj1266's Avatar
Here is what I have for this Evo 9. TBE w/stock cat and Injen intake w/uicp. Top part is the logged boost, 2 byte load, load error and WGDC correction. Bottom part is BDEL+BCLO and TBEC. 4 back to back logs on 91 octane gas. All numbers are averages.
I want to thank razorlab for the tip of setting BCLO to 200. It makes math so much easier
Old Apr 19, 2008 | 09:05 PM
nonschlont's Avatar
That looks like my rom. Thanks Naji. And thank you razorlab for the tip, it definitely makes the math much easier!
kons6
May 26, 2016 02:41 AM
ridenrunwv
Sep 19, 2015 06:42 PM
razorlab
Mitsubishi TC-SST Discussion
Feb 8, 2011 07:17 PM
Shadowpriest
May 5, 2008 12:39 PM
350ZTracktoEvo8
Jul 20, 2003 01:07 PM
