How-To: Log Estimated Boost in EvoScan
Old Apr 29, 2008 | 03:33 AM
recompile's Avatar
I'm not sure if anyone did a write up for this yet. I'm sure it's been done before, but I didn't come up with any search results, so just in case...
You can log estimated boost by converting 2ByteLoad (kPa) to psi. This is a pretty simple, process...
1. Make sure you're logging 2ByteLoad
2. Add this to your EvoScan Data.xml:
<DataListItem DataLog="Y" Color="" Display="EstBoost" LogReference="EstBoost" RequestID="00" RequestID2="01" Eval="(0.3125x-100)*.145" Unit="psig" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-10" GaugeMax="30" ChartMin="-10" ChartMax="30" ScalingFactor="1" Notes=""/>
It's not perfect, of course, but it's close. Here's a comparison from a log of mine:
Old Apr 29, 2008 | 03:58 AM
recompile's Avatar
Also, I'm not sure if this calculation needs correction for different atmospheric pressures... I'm pretty much at sea level so I can't really test this.
If someone else wants to test, you can put your local atmospheric pressure in and see if that's more accurate than the formula in the OP.
Go to www.weather.com, enter your zip code, and get the Pressure in inches, multiply this by 3.376
So for me it's:
29.75 in x 3.376 = 100.4 (round to 100)
Old Apr 29, 2008 | 05:37 AM
l2r99gst's Avatar
Unfortunately, load isn't kpa like some people believe. Load is a mass airflow per rev, so the load number can very dramatically from car to car, conditions to conditions, for the same psi.
I made a thread on a way to approximate boost a while back here.
In post #4 I showed how much boost can vary with the same load.
Here is the equation that I came up with...test it out with your data to see how well it matches, as I didn't really get any response to that thread:
BoostEst=[(load*T)/(P*VE*280)]-14.7
T = actual intake air temp (not MAF temp) in degrees Rankin (degrees F +460)
P = atmospheric pressure in psi at the MAF(baro)
VE = VE of engine at the RPM being measured
The only problem is that you need to know your actual intake temp, not the temp at the MAF and your VE. VE of the 4G63 is about 1 at 5500 or so, so I used that RPM point for most of my calculations. For intake temps, depending on the IC, I used ambient plus 20* or 40* or 60*...all depending on what IC/boost etc.
Actually, this equation is a good way to find your VE curve or your intake temps, if you are actually logging boost and know one of the other variables.
Eric
Old Apr 29, 2008 | 06:52 PM
recompile's Avatar
Interesting read... I might have been too optimistic thinking we could estimate boost that easily.
Can some people who have JDM map test this equation in Excel against some of their logs and post the comparison of EstBoost vs. JDM MAP ?
Code:
=(2ByteLoad-LocalAtmospheric)*.145
If you're not sure of your local atmospheric, you can go to www.weather.com, enter your zip code, and get the Pressure in inches, multiply this by 3.376
So for me it's:
Code:
=(2ByteLoad-100)*.145
Old Apr 29, 2008 | 07:35 PM
kreionic's Avatar
I will gladly try give this a try for you tomorrow morning . I am basically at sea level as well so I will just use your same equation
Old May 6, 2008 | 09:43 AM
inco9nito99's Avatar
updates?
Old May 6, 2008 | 10:01 AM
kstpeter33's Avatar
subscribed
Old May 6, 2008 | 10:14 AM
kstpeter33's Avatar
i added the coding to my data.xml file but it doesnt show up as an option to log when i open evoscan?
Old May 6, 2008 | 10:56 PM
Shadowpriest's Avatar
Here is an example of log not correlating to boost as expected
Evo IX
3rd gear pull
2-byte load, 2-byte rpm, JDM MAP sensor adjusted for local atmospheric
Log point: 3218.75 RPM
2-byte load: 230
JDM MAP: 18.02psi
Log Point: 3433.594 RPM
2-byte load:218.438
JDM MAP: 18.396
Log Point: 3582.031RPM
2-byte load:210.313
JDM MAP: 18.59
roger smith
Oct 29, 2018 03:23 AM
GST Motorsports
113
Feb 14, 2017 06:09 AM
Mattjin
Apr 16, 2009 02:22 PM
mrfred
Feb 22, 2009 08:24 PM
JohnBradley
Dec 9, 2007 07:55 AM
